AOC 18.5" widescreen 931SWL 5ms LCD TFT
LOW PRICE STYLISH AOC MONITOR!
Quicklinx: 64SRWS00 Mfr#: 931SWL
Highlights of the AOC 18.5" widescreen 931SWL monitor
Screen: 18.5" widescreen (1366 x 768)
Brightness: 200 cd/m2
Dynamic Contrast Ratio: 10000:1
Response time: 5ms
Connectivity: D-sub
Aspect Ratio: 16:9
VESA Wall mountable (100mm x 100mm)
3 years warranty
AOC 931Swl - LCD monitor - 18.5"
LCD monitor - 18.5"
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
1000:1 / 10000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, hard coating
Voltage
Piano black
45.5 cm x 22 cm x 35.8 cm
3.9 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV, cUL, DDC-2B, DDC-2Bi, TUV S, CCC, FCC, RoHS
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
18.5"
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Video Bandwidth
85.5 MHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
50
Screen Coating
Eco-Mode, anti-glare
Piano black
3.9 kg
VGA
Mechanical
Tilt
Tilt Angle
25
VESA Mounting Interface
100 x 100 mm
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
25 Watt
Power Consumption Stand by / Sleep
1 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
