Antec's VP PC power supplies promise one thing: quality performance at an incredible value. This entry-level solution gives you everything you need in a power supply, and nothing you don't. No bells. No whistles. No nonsense.
- Antec VP500PC - power supply - 500 Watt
- Power supply - internal
- 1.45 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Power Capacity
- 500 Watt
- Output Current
- +5V - 18 A , +3.3V - 22 A , +12V1 - 24 A , +12V2 - 21 A , -12V - 0.3 A , +5VSB - 2.5 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 3 x 4 PIN internal power , 4 x 15 pin Serial ATA power , 1 x 6 pin PCI Express power , 1 x 4 PIN mini-power connector
- Cooling System
- 120 mm fan
- 2-year warranty
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Power Capacity
- 500 Watt
- Output Current
- Efficiency
- 82%
- Cooling System
- 120 mm fan
- Thermal monitoring, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, surge & inrush protection, no load operation & brown-out protection, CircuitShield
- CB, CCC, RoHS, Energy-Related Products (ErP) Lot 6
- Limited warranty - 2 years
- 1.45 kg
- Shipping Width
- 26 cm
- Shipping Depth
- 12 cm
- Shipping Height
- 21 cm
- Shipping Weight
- 1.75 kg
