Antec P183 V3 Black ATX Mid Tower Case
Quicklinx: 7KP1WS00 Mfr#: 0761345-81834-6
The Antec P183 epitomizes cooling, quiet and sophistication. An Antec-exclusive three-layer side and front panel design (aluminum, plastic, aluminum) reduces noise and ensures quiet computing. The P183 also boasts a dual chamber design that isolates the power supply from the rest of the components, minimizing heat and reducing system noise. Additional features include two internal 2.5" SSD bays, an external control for fans, cable management and a special gunmetal gray finish for one-of-a-kind style.
Antec Performance One P183 V3 - tower - ATX
System cabinet
Tower
I/O Connectors
3 x USB 3.0 , 1 x microphone , 1 x headphones
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Noise reduction, front panel door, CPU cut-out
No power supply
20.5 cm x 50.7 cm x 54 cm
Tower
Max Mainboard Size
ATX
Internal Bays Qty
8
Front Accessible Bays Qty
5
Cooling System
Rear: 120 mm fan x 1 , Top: 120 mm fan x 1 , Front: 120 mm fan x 2
Expansion Bays
4 (total) / 4 (free) x front accessible - 5.25" x 1/2H , 1 (total) / 1 (free) x front accessible - 3.5" x 1/3H , 6 (total) / 6 (free) x internal - 3.5" x 1/3H , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
7 x Expansion Slot
3 x USB 3.0 , 1 x microphone - mini-jack , 1 x headphones - mini-jack
RoHS
No power supply
Max Supported Qty
1
20.5 cm
50.7 cm
54 cm
