The NSK3 100 was designed to compliment any home or office with its black matte exterior and sleek from bezel with indirect intake vents. In addition to its striking appearance, the NSK3 100 is constructed of SECC steel 40% thinker than competitors in its class. A balance of versatility and durability is achieved by integrating Antec's proprietary Quiet Computing technology with solid build quality and superior components. It contains two fan mounting points with room for four expansion slots. Finally, the front 110 ports include two USB 3.0 and audio sockets.
Versatile cooling options
Equipped with a 92 mm rear fan and a front fan mount supporting up to an 80 mm fan, the NSK3100 ensures efficient airflow management to keep your components cool. -
Spacious expansion
With three front accessible bays, three internal bays, and four expansion slots, the NSK3100 offers ample room for storage and customization, accommodating a wide range of system configurations. -
Enhanced compatibility
Supporting both mini ITX and micro ATX motherboards, the NSK3100 is designed to be flexible for various builds, ensuring compatibility with a broad selection of hardware. -
Robust connectivity
Featuring two USB 3.0 ports, audio line-out/headphones, and microphone mini-jack connectors, the NSK3100 provides convenient access to essential connections for a seamless user experience.
- Antec New Solution NSK3100 - tower - mini ITX / micro ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Matte black
- I/O Connectors
- 2 x USB 3.0 , 1 x audio line-out/headphones , 1 x microphone
- Supported Motherboards
- microATX, Mini-ITX
- System Cabinet Features
- Thermally Advantaged Chassis (TAC), liquid cooling holes
- Power Device
- No power supply
- 18 cm x 41.1 cm x 36 cm
- 6.8 kg
- 3-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Mini ITX / micro ATX
- Internal Bays Qty
- 3
- Front Accessible Bays Qty
- 3
- Matte black
- Cooling System
- Rear: 92 mm fan x 1 , Front: 80 mm fan mount x 1
- Video Card Max Length
- 317.5 mm
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" x 1/2H , 1 (total) / 1 (free) x front accessible - 3.5" , 2 (total) / 2 (free) x internal - 3.5" , 1 (total) / 1 (free) x internal - 2.5"
- Expansion Slots
- 4
- 2 x USB 3.0 , 1 x audio line-out/headphones - mini-jack , 1 x microphone - mini-jack
- RoHS
- Power Device
- No power supply
- 18 cm
- 41.1 cm
- 36 cm
- 6.8 kg
- Limited warranty - 3 years
