Antec NSK3100 Micro ATX Case No PSU USB 3.0 1 x Fan Matte Black
Quicklinx: 9PLVWS00 Mfr#: 0-761345-93100-7
The NSK3 100 was designed to compliment any home or office with its black matte exterior and sleek from bezel with indirect intake vents. In addition to its striking appearance, the NSK3 100 is constructed of SECC steel 40% thinker than competitors in its class. A balance of versatility and durability is achieved by integrating Antec's proprietary Quiet Computing technology with solid build quality and superior components. It contains two fan mounting points with room for four expansion slots. Finally, the front 110 ports include two USB 3.0 and audio sockets.
  • Versatile cooling options
    Equipped with a 92 mm rear fan and a front fan mount supporting up to an 80 mm fan, the NSK3100 ensures efficient airflow management to keep your components cool.
  • Spacious expansion
    With three front accessible bays, three internal bays, and four expansion slots, the NSK3100 offers ample room for storage and customization, accommodating a wide range of system configurations.
  • Enhanced compatibility
    Supporting both mini ITX and micro ATX motherboards, the NSK3100 is designed to be flexible for various builds, ensuring compatibility with a broad selection of hardware.
  • Robust connectivity
    Featuring two USB 3.0 ports, audio line-out/headphones, and microphone mini-jack connectors, the NSK3100 provides convenient access to essential connections for a seamless user experience.
Antec New Solution NSK3100 - tower - mini ITX / micro ATX
System cabinet
Tower
Matte black
I/O Connectors
2 x USB 3.0 , 1 x audio line-out/headphones , 1 x microphone
Supported Motherboards
microATX, Mini-ITX
System Cabinet Features
Thermally Advantaged Chassis (TAC), liquid cooling holes
No power supply
18 cm x 41.1 cm x 36 cm
6.8 kg
3-year warranty
Tower
Max Mainboard Size
Mini ITX / micro ATX
microATX, Mini-ITX
Internal Bays Qty
3
Front Accessible Bays Qty
3
Matte black
Cooling System
Rear: 92 mm fan x 1 , Front: 80 mm fan mount x 1
Video Card Max Length
317.5 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" x 1/2H , 1 (total) / 1 (free) x front accessible - 3.5" , 2 (total) / 2 (free) x internal - 3.5" , 1 (total) / 1 (free) x internal - 2.5"
Expansion Slots
4
2 x USB 3.0 , 1 x audio line-out/headphones - mini-jack , 1 x microphone - mini-jack
RoHS
No power supply
18 cm
41.1 cm
36 cm
6.8 kg
Limited warranty - 3 years
