Antec NSK-1380-UK Black MATX Cube 350W PSU
Customer rating: 5.0* (Write a review)
Quicklinx: 4V4GWS00 Mfr#: 0-761345-00136-6
The small and compact cubic design of the NSK1380 allows it to fit into virtually any workspace while the inside is spacious enough for your microATX motherboard, up to 4 full height PCI expansion cards, and 4 drive bays. The NSK1380's power supply is 80 PLUS certified, ensuring that it consumes less electricity and saves you money on your power bill, with no reduction in quality performance! This case is so versatile that it can be used as a multimedia PC for your living room, a desktop PC for your office, or even a mobile gaming box for your next LAN party.
  • Compact design
    The Antec New Solution NSK1380 -UK features a tower form factor, offering a compact and efficient design that fits well in any workspace. Its small footprint does not compromise on internal space, with ample room for expansion.
  • Efficient cooling
    Equipped with a 12 cm fan, this chassis ensures optimal cooling for your PC components, maintaining performance while minimizing noise.
  • Expandable storage
    With three internal 3.5" bays and one front accessible 5.25" bay, the NSK1380 -UK provides flexibility for additional storage, making it easy to upgrade your system as your needs grow.
  • High compatibility
    Supporting microATX motherboards, this chassis is designed to accommodate a wide range of system configurations, ensuring compatibility with a variety of components.
  • Energy efficient
    Featuring an 80 PLUS certified power supply with 350 W and active Power Factor Correction (PFC), the NSK1380 -UK delivers efficient power to your system, reducing electricity usage and costs.
Antec New Solution NSK1380 -UK - tower - micro ATX
System cabinet
Tower
United Kingdom
I/O Connectors
2 x USB , 1 x audio line-out , 1 x microphone
Installed Fans Qty
1
Supported Motherboards
microATX
Power supply 350 Watt (ATX12V 2.01)
AC 120/230 V
20.1 cm x 33.5 cm x 26.9 cm
5.9 kg
3-year warranty
Tower
Max Mainboard Size
Micro ATX
microATX
Internal Bays Qty
3
Front Accessible Bays Qty
1
Fans
Internal: 1 x 12 cm - (1 installed)
United Kingdom
Expansion Bays
1 (total) / 1 (free) x front accessible - 5.25" x 1/2H , 3 (total) / 3 (free) x internal - 3.5" x 1/3H
Expansion Slots
4 x full-height
2 x USB , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
RoHS
Power supply
Specification Compliance
ATX12V 2.01
Installed Qty
1
Max Supported Qty
1
AC 120/230 V
Power Provided
350 Watt
Power Supply Features
Active Power Factor Correction (PFC)
80 PLUS Certification
80 PLUS
20.1 cm
33.5 cm
26.9 cm
5.9 kg
Limited warranty - 3 years
Customer reviews
Write a review for the Antec NSK-1380-UK Black MATX Cube 350W PSU here!
Nice case Poor Power Supply
Reviewed by Mike Vogwell. Review Posted 16/11/2008
I bought one of these a year ago to build a media PC. Unfortunately a year on the PSU died, and is not a standard. managed to bodge in a PSU from Maplin, which works but is noisier than the original. I wouldn't buy this case again.
  • Overall 5*
  • Ease of use 4*
  • Value for money 4*
Have bought 6 of these
Reviewed by alex. Review Posted 08/11/2008
I've upgraded 6 systems at one of my customers, using these cases. The cases are well made and very quiet especially with current Intel dual core processors fitted. Systems run cool in normal office use. So far no problems, and the customer is pleased with the looks. Buying another one for a different customer this week.
  • Overall 5*
  • Ease of use 5*
Great case - replacement PSU pricey
Reviewed by A M. Review Posted 17/04/2008
I had the predecessor for 5 years + with no problems, but the PSU has just started to die.
Unfortunately a replacement PSU is about £50! (and I can only find it in one place).
Trouble is I can't find any equivalent sized case so will probably buy another!
  • Overall 5*
  • Ease of use 5*
Read all 9 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
