Antec MX 25 Aluminium Hard Drive Enclosure
Quicklinx: 7374WS00 Mfr#: 0761345-00712-2
Realize your data transfer potential with the incredibly versatile and easy-to-use MX-25, the portable 2.5" hard drive enclosure. With a dual USB 2.0 and eSATA interface and 3-head USB cable, the extremely lightweight MX-25 supports SATA hard drives up to 500GB without breaking a sweat. No external power adapter is required, simply install your drive, connect it to your computer, and start transferring data at up to 480Mbps and 3Gbps, respectively. Make life easier for you and your data with the MX-25, the smaller, more versatile 2.5" hard drive enclosure.
Antec VERIS MX-25 - storage enclosure - SATA 3Gb/s - eSATA 3Gb/s, USB 2.0
Storage enclosure - external
Bus Type
Europe
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
Power Source
Optional AC adapter
Microsoft Windows 2000, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista
8.2 cm x 1.8 cm x 13.4 cm
191 g
3-year warranty
2.5"
Host Bus
Europe
Storage Controller
SATA 3Gb/s
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive
No CPU
Bays
1 x internal - 2.5"
1 x SATA 3Gb/s - SATA
1 x USB 2.0 - 4 pin USB Type B , 1 storage - eSATA-300
1 x USB cable - external
RoHS
Power Source
Optional AC adapter
Limited warranty - 3 years
8.2 cm
1.8 cm
13.4 cm
191 g
