Mini-ITX is the next "big" thing. The ISK 310-150 is designed exclusively for Mini-ITX motherboards. With three drive bays, a quiet 80mm TriCool fan, and a 150-watt power supply, the ISK 310-150 can handle many of the tasks of a traditional PC, in a fraction of the space. Plus, its stylish, silver front bezel will fit in perfectly with your existing multimedia components. From petite desktop option to silent home theater, Antec's ISK 310-150 is an epic case of mini proportions.
Compact design
The Antec ISK310-150 features a small form factor chassis, making it an ideal choice for users looking to build a compact PC without sacrificing functionality. Its sleek design allows for easy integration into any workspace, ensuring a minimal footprint. -
Efficient power
Equipped with a 150 W power adapter, this model provides a reliable and efficient power supply, supporting all the necessary components for a mini ITX build. Its power efficiency is perfect for everyday computing needs. -
Expandable storage
With one front accessible bay and two internal bays for storage, the Antec ISK310-150 offers ample space for hard drives or SSDs. This flexibility allows users to easily expand their storage based on their needs, ensuring that space is never a constraint. -
Versatile connectivity
Front panel connectors including USB, Audio, and E-SATA ports, alongside dedicated headphone and microphone jacks, offer users a wide range of connectivity options. This versatility ensures that all peripheral devices can be connected with ease.
- Antec ISK310-150 - SFF - mini ITX
- Product Type
- System cabinet
- Form Factor
- Small form factor
- Black, silver
- Localisation
- United Kingdom
- I/O Connectors
- 2 x USB 2.0 , 1 x eSATA , 1 x headphones , 1 x microphone
- Installed Fans Qty
- 1
- Supported Motherboards
- Mini-ITX
- System Cabinet Features
- Manual fan speed control
- Power Device
- Power adapter 150 Watt
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 22.2 cm x 32.8 cm x 9.6 cm
- 2.5 kg
- 3-year warranty
- Form Factor
- Small form factor
- Max Mainboard Size
- Mini ITX
- Mini-ITX
- Internal Bays Qty
- 2
- Front Accessible Bays Qty
- 1
- Black, silver
- Fans
- Side: 1 x 8 cm - (1 installed)
- Localisation
- United Kingdom
- Expansion Bays
- 1 (total) / 1 (free) x front accessible - 5.25" Slim Line , 2 (total) / 2 (free) x internal - 2.5"
- Expansion Slots
- 1 x Expansion Slot
- 2 x USB 2.0 , 1 x eSATA , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- RoHS
- Power Device
- Power adapter
- Installed Qty
- 1
- Max Supported Qty
- 1
- Voltage Required
- Power Provided
- 150 Watt
- 22.2 cm
- 32.8 cm
- 9.6 cm
- 2.5 kg
- Limited warranty - 3 years
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.02 |
