Antec ISK 310-150 Mini-ITX Desktop
Quicklinx: 7370WS00 Mfr#: 0761345-08185-6
Mini-ITX is the next "big" thing. The ISK 310-150 is designed exclusively for Mini-ITX motherboards. With three drive bays, a quiet 80mm TriCool fan, and a 150-watt power supply, the ISK 310-150 can handle many of the tasks of a traditional PC, in a fraction of the space. Plus, its stylish, silver front bezel will fit in perfectly with your existing multimedia components. From petite desktop option to silent home theater, Antec's ISK 310-150 is an epic case of mini proportions.
  • Compact design
    The Antec ISK310-150 features a small form factor chassis, making it an ideal choice for users looking to build a compact PC without sacrificing functionality. Its sleek design allows for easy integration into any workspace, ensuring a minimal footprint.
  • Efficient power
    Equipped with a 150 W power adapter, this model provides a reliable and efficient power supply, supporting all the necessary components for a mini ITX build. Its power efficiency is perfect for everyday computing needs.
  • Expandable storage
    With one front accessible bay and two internal bays for storage, the Antec ISK310-150 offers ample space for hard drives or SSDs. This flexibility allows users to easily expand their storage based on their needs, ensuring that space is never a constraint.
  • Versatile connectivity
    Front panel connectors including USB, Audio, and E-SATA ports, alongside dedicated headphone and microphone jacks, offer users a wide range of connectivity options. This versatility ensures that all peripheral devices can be connected with ease.
Antec ISK310-150 - SFF - mini ITX
System cabinet
Small form factor
Black, silver
United Kingdom
I/O Connectors
2 x USB 2.0 , 1 x eSATA , 1 x headphones , 1 x microphone
Installed Fans Qty
1
Supported Motherboards
Mini-ITX
System Cabinet Features
Manual fan speed control
Power adapter 150 Watt
22.2 cm x 32.8 cm x 9.6 cm
2.5 kg
3-year warranty
Small form factor
Max Mainboard Size
Mini ITX
Mini-ITX
Internal Bays Qty
2
Front Accessible Bays Qty
1
Black, silver
Fans
Side: 1 x 8 cm - (1 installed)
United Kingdom
Expansion Bays
1 (total) / 1 (free) x front accessible - 5.25" Slim Line , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
1 x Expansion Slot
2 x USB 2.0 , 1 x eSATA , 1 x headphones - mini-jack , 1 x microphone - mini-jack
RoHS
Power adapter
Installed Qty
1
Max Supported Qty
1
Power Provided
150 Watt
22.2 cm
32.8 cm
9.6 cm
2.5 kg
Limited warranty - 3 years
7370 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.02
