Antec ISK 300-150 Mini-ITX Desktop Case
Quicklinx: 76C6WS00 Mfr#: 0761345-08175-7
Mini-ITX is the next "big" thing. And now, Antec introduces the ISK 300-150, designed exclusively for Mini-ITX motherboards. With three drive bays, a quiet 80mm TriCool fan, and a stable 150-watt power supply, the ISK 300-150 can handle many of the tasks of a traditional PC, but in half the space. From petite desktop options to silent home theater, Antec's ISK 300-150 is an epic case of mini proportions.
  • Compact design
    The Antec ISK300-150 stands out with its small form factor, making it an ideal choice for users looking to save space without compromising on functionality. Its sleek design allows for easy integration into any workspace, providing a clutter-free environment.
  • Efficient power
    Equipped with a 150-watt power adapter, this chassis ensures efficient power usage while supporting all the necessary components for a mini ITX system. It's designed to keep your system running smoothly, even under load.
  • Versatile expansion
    Offering a front accessible bay and two internal bays for storage, alongside an expansion slot, the ISK300-150 provides ample room for system upgrades and expansions. This flexibility allows users to customize their setup as needed, ensuring longevity and adaptability of their computing environment.
Antec ISK300-150 - SFF - mini ITX
System cabinet
Small form factor
United Kingdom
I/O Connectors
2 x USB 2.0 , 1 x eSATA , 1 x headphones , 1 x microphone
Installed Fans Qty
1
Supported Motherboards
Mini-ITX
System Cabinet Features
Manual fan speed control
Power adapter 150 Watt
22.2 cm x 32.8 cm x 9.6 cm
2.5 kg
3-year warranty
Small form factor
Max Mainboard Size
Mini ITX
Mini-ITX
Internal Bays Qty
2
Front Accessible Bays Qty
1
Fans
Side: 1 x 8 cm - (1 installed)
United Kingdom
Expansion Bays
1 (total) / 1 (free) x front accessible - 5.25" Slim Line , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
1 x Expansion Slot
2 x USB 2.0 , 1 x eSATA , 1 x headphones - mini-jack , 1 x microphone - mini-jack
RoHS
Power adapter
Installed Qty
1
Max Supported Qty
1
Power Provided
150 Watt
22.2 cm
32.8 cm
9.6 cm
2.5 kg
Limited warranty - 3 years
Resources
The following resources are available for the Antec ISK 300-150 Mini-ITX Desktop Case
