Designed specifically for gamers inside - out, from its spacious interior, to an aesthetically appealing exterior. It’s a blend of quality and features with a rugged strong appearance. The GX200 is filled with features that allow building a professional gaming system with ease. It comes with full black coating inside and out, a front panel grill that improves both air intake and adds style. The convenient top storage easily lets you place your additional accessories and mobile devices for easy accessibility. This chassis offers a great mid-tower case for your mainstream PC build - without completely emptying your wallet. Give yourself an unbelievable gaming experience with Antec’s GX200.
- Antec GX200 - mid tower - ATX
- Product Type
- System cabinet
- Form Factor
- Mid tower
- Blue
- I/O Connectors
- 1 x USB 2.0 , 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Screwless drive bays, removable dust filter
- Power Device
- No power supply
- 18.5 cm x 45 cm x 41.2 cm
- 4.3 kg
- Form Factor
- Mid tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 5
- Front Accessible Bays Qty
- 1
- Blue
- Cooling System
- Front: 120 mm fan mount x 2 , Rear: 120 mm fan mount x 1
- CPU Cooler Max Height
- 158 mm
- Video Card Max Length
- 380 mm
- Expansion Bays
- 1 (total) / 1 (free) x front accessible - 5.25" , 4 (total) / 4 (free) x internal - 3.5" , 1 (total) / 1 (free) x internal - 2.5"
- Expansion Slots
- 7
- 1 x USB 2.0 , 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- RoHS
- Power Device
- No power supply
- 18.5 cm
- 45 cm
- 41.2 cm
- 4.3 kg
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.03 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £4.28 |
C2G 2-Port USB 2.0 Manual Switch | In Stock | £16.49 |
C2G 5m USB 2.0 A Male to A Female Active Extension Cable | In Stock | £11.53 |
C2G 4-Port USB 2.0 Aluminum Hub | In Stock | £25.75 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £15.20 |
C2G USB 2.0 To Fast Ethernet Adapter | In Stock | £19.21 |
