The flagship in Antec's gaming series, the Eleven Hundred, brings ultimate gaming builds to life. The Eleven Hundred's nine expansion slots and space for the motherboard accommodate elite GPU configurations up to 3-way NVIDIA SLI/4-way AMD CrossFireX.
The Eleven Hundred also lets you organize a clean, powerful build with superior cable routing, including 36 mm of space behind the motherboard tray and grommet-lined cable routing holes.
- Compatible with up to 3-way NVIDIA® SLI® / 4-way AMD CrossFireX™
- Grommet-lined cable routing holes with 36 mm of space behind the motherboard tray
- 2 front panel USB 3.0 ports
- Included 200 mm blue LED top fan / 120 mm rear fan / 7 additional fan mounts
- Fan connector PCB: allows you to connect four 3-pin fans to a single Molex for improved cable management
- PSU intake & front air filters
- 120 mm intake fan behind motherboard (optional)
- 3 tool-less 5.25" drive bays
- 6 x 3.5" tool-less drive bays (rail-mount design)
- Model Eleven Hundred
- Case Type Mid-Tower
Color(s) Black
Cooling System - One 200 mm blue LED top fan
- One 120 mm rear fan
- One 120 mm intake fan behind. motherboard for CPU cooling (optional)
- Two 120 mm internal intake fans (optional)
- Two 120 mm front intake fans (optional)
- Two 120 mm side panel fans to cool graphic cards (optional)
Fan power hub (allows you to connect four 3-pin fans to a single Molex for improved cable management)
Drive Bays - Three 5.25" tool-less drive bays / Two 2.5" drive bays (dedicated) / Six 3.5" tool-less drive bays (rail-mount design)
- Front Ports - Two USB 3.0 with internal motherboard connector / Two USB 2.0 / Audio In/Out
- Expansion Slots / video card size - Nine expansion slots / 13" (330 mm) video card size
- Maximum CPU cooler height 6.7" (170 mm)
- PSU None
- Motherboard Support XL-ATX [13.6" x 10.3" (345 mm x 262 mm)], Standard ATX, microATX, Mini-ITX)
- CPU Cutout Enlarged CPU Cutout
- Cable Management Grommet-lined cable routing holes with 36 mm of space behind the motherboard tray
- Side panel features - Side Panel Window (Right side) / Two 120 mm fan mounts (Right side - Optional) / One 120 mm fan mount behind motherboard (Left side - Optional)
- Dimensions - 20.7" (H) x 9.3" (W) x 21.5" (D) / 527 mm (H) x 237 mm (W) x 546 mm (D)
- Weight - Net weight: 15.3 lbs / 6.9 kg
- Antec Eleven Hundred - tower - XL-ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- I/O Connectors
- 2 x USB , 2 x USB 2.0 , 1 x microphone , 1 x speakers
- Supported Motherboards
- ATX, microATX, Mini-ITX, XL-ATX
- Power Device
- No power supply
- 23.7 cm x 54.6 cm x 52.7 cm
- 9 kg
- Form Factor
- Tower
- Max Mainboard Size
- XL-ATX
- Internal Bays Qty
- 5
- Front Accessible Bays Qty
- 6
- Cooling System
- Top: 200 mm fan x 1 / blue LED , Rear: 120 mm fan x 1 , 120 mm fan mount x 1 , Internal: 120 mm fan mount x 2 , Front: 120 mm fan mount x 2 , Side: 120 mm fan mount x 2
- Expansion Bays
- 3 (total) / 3 (free) x front accessible - 5.25" x 1/2H , 2 (total) / 2 (free) x front accessible - 2.5" , 6 (total) / 6 (free) x internal - 3.5" x 1/3H
- RoHS
- Power Device
- No power supply
- 23.7 cm
- 54.6 cm
- 52.7 cm
- 9 kg
