Antec 900W High Current Gamer 80plus Bronze PSU
Quicklinx: 7N3FWS00 Mfr#: 0-761345-06221-3
Making quad rail power and highly advanced power supply design available at a popular wattage, the HCG-900 features special high current connectors and heavy-duty cabling, earning it NVIDIA SLI-ready and ATI CrossFire certifications. At the same time the HCG-900 is also 80 PLUS Bronze certified for efficiency, and features active PFC with a swift, quiet double ball bearing fan so you know you're getting not only high current, but also high efficiency and excellent cooling. If loads of power, high current engineering and exceptional efficiency are what you're after, the HCG-900 is the perfect PSU for you.
  • 135 mm double ball bearing fan
    The double ball bearing fan provides both quiet and high air flow.
  • Four high current +12V rails with high OCP set point
    Four high current +12V rails with high OCP set point ensure excellent graphics card compatibility.
  • Japanese-brand capacitors
    Japanese-brand capacitors ensure exceptional reliability.
Antec High Current Gamer HCG-900 - power supply - 900 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V 2.91
80 PLUS Certification
80 PLUS Bronze
2.7 kg
United Kingdom
Input Voltage
AC 100-240 V
Power Capacity
900 Watt
Output Current
+5V - 25 A / 0 A , +12V1 - 40 A / 0 A , +12V2 - 40 A / 0 A , +12V3 - 40 A / 0 A , +12V4 - 40 A / 0 A , -12V - 0.5 A / 0 A , +5VSB - 3 A / 0 A , +3.3V - 25 A / 0 A
Output connectors
4 x 8 pin PCI Express power with detachable 2 pin section , 9 x 15 pin Serial ATA power , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x power 24 pin ATX with detachable 4 pin section , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Cooling System
140 mm fan
15 cm x 18 cm x 8.6 cm
5-year warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Margin
+ 10% / - 10%
Frequency Required
47 - 63 Hz
Power Capacity
900 Watt
Output Current
80 PLUS Bronze
MTBF
100,000 hours
Cooling System
140 mm fan
Overheat protection, gold-plated terminals, over current protection, over voltage protection, overpower protection, SLI ready, CrossFire ready, quad 12V rails, short-circuit protection, dual ball bearing cooling fan
TUV, C-Tick, BSMI, cUL, CB, CCC, FCC, RoHS, GOST-R
Limited warranty - parts and labour - 5 years
50 °C
15 cm
18 cm
8.6 cm
2.7 kg
Shipping Width
31 cm
Shipping Depth
18 cm
Shipping Height
12.4 cm
Shipping Weight
3.4 kg
