Antec 900 Nine Hundred Ultimate Gamer Case (Black)
Customer rating: 5.0* (Write a review)
Quicklinx: 49XSWS00 Mfr#: 0761345-08009-5
The most versatile gaming case EVER
Introducing the Antec Nine Hundred hardcore gaming case. Now you can own any noob ever spawned with this ultra-mean case in classic black finish. Antec knows your gaming hardware produces a lot of heat, that's why the case is built for maximum cool with a perforated front bezel, three 120mm fans with mounts for even more fans, and a monster top-mounted 200mm! The versatile Nine Hundred is maximally customizable to fit your needs. The modular design lets you modify the placement of the front fans and hard drive cages. There's even a tray on top for your mp3 player, digital camera, or that spare illudium Q-42 explosive space modulator that you have lying around. Be the envy of everyone at your next LAN party, impress your friends, and just generally show everyone that you are the ultimate master of all time with the Antec Nine Hundred!
Often replicated, never duplicated: Meet the Antec Nine Hundred, the original re-configurable gamer enclosure. It's got perforated front, rear and side panels and space for up to nine drives, four standard fans and two optional fans. Inside, you'l find a bottom PSU mount and top-mount Big Boy 200™ exhaust fan air, fed by matching blue-LED illuminated front fans with black blades. Up top, convenient front inputs and a top tray allow convenient plugging in and storage of MP3 players or portable hard drives. With serious convenience and outrageous style, the Nine Hundred is your go-to case for performance air-cooled builds.
Antec Nine Hundred - tower - ATX
System cabinet
Tower
Windowed Side Panel
Classic black
Europe
I/O Connectors
2 x USB , 1 x FireWire , 1 x microphone , 1 x audio line-out
Installed Fans Qty
4
Supported Motherboards
ATX, microATX
System Cabinet Features
Built-in UV-blue LEDs
No power supply
20.6 cm x 49.3 cm x 46.8 cm
8.4 kg
3-year warranty
Tower
Windowed Side Panel
Max Mainboard Size
ATX
ATX, microATX
Front Accessible Bays Qty
9
Classic black
Fans
Top: 1 x 20 cm - (1 installed) , Rear: 1 x 12 cm - (1 installed) , Front: 2 x 12 cm - (2 installed) , Side: 1 x 12 cm - (0 installed) , Internal: 1 x 12 cm - (0 installed)
Europe
Expansion Bays
9 (total) / 9 (free) x front accessible - 5.25"
Expansion Slots
7 x Expansion Slot
2 x USB , 1 x FireWire - 6 pin FireWire , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack
RoHS
No power supply
Max Supported Qty
1
20.6 cm
49.3 cm
46.8 cm
8.4 kg
Limited warranty - 3 years
Resources
The following resources are available for the Antec 900 Nine Hundred Ultimate Gamer Case (Black)
Customer reviews
Write a review for the Antec 900 Nine Hundred Ultimate Gamer Case (Black) here!
Brilliant
Reviewed by . Review Posted 02/04/2008
Great case Pros: Looks great with all the LED fans. Keeps computer really cool. Very good price. Very quite on low fan speed. Cons: Not as much room as I was hoping for - but it fits my 8800GTX. Overall I am very happy with this case. It is the first gaming case I have bought so I don’t really have anything else to compare it to. But I would definitely buy another one. Excellent delivery time as usually with Dabs – ordered Sunday and arrived Tuesday.
  • Overall 5*
  • Ease of use 4*
  • Value for money 5*
excellent
Reviewed by Chris. Review Posted 26/02/2009
beast of a case, it's cut my temperatures in half, an overclocked e8400 (3ghz) sitting at 4ghz barely breaks a sweat at 45C under load (prime 95)
the case is well built and has thumb screws almost throughout which is useful for those times when a philips head screwdriver doesn't want to be found!
slighly gutted i never got it for 69 quid like the dude below but it was well worth every bit of the 86 i spent on it.
as for the below dilemma with front loading bays, if you move your hard drives down to the bottom adjacent to the power supply, you can remove one of the HDD caddies, and there's another 3 5.25" bays sitting there, it limits you to 3 hard drives but with drives heading for 2TB apiece, you won't need many.
  • Overall 5*
  • Ease of use 5*
great case
Reviewed by c.. Review Posted 14/01/2009
Had this now since december 2007. only fault so far is the top fan stops and needs a tap to get going again, apart from that its solid, looks good and is cool. Cost me a few pence over £68 then, now is over £80 as i write this. I got a bargain then.
  • Overall 5*
  • Ease of use 5*
Read all 27 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
