Let the Games Begin
The team that brought you the Three Hundred is back with an enclosure designed to handle today and tomorrow's high-performance systems. Introducing the Three Hundred Two, the next standard in affordable gaming cases. Our newest chassis is built for gamers from the inside-out, from its aggressive front bezel, to its advanced cooling system. With tool-less 5.25" & 3.5" drive bays, a large cable management compartment and two front panel USB 3.0 ports with an internal connector, the Three Hundred Two is the rightful heir to the Gaming Series legacy
- 11 drive bays: 3 x 5,25" tool-less drive bays / 2 x 2,5" drive bays (dedicated) / 6 x 3,5" tool-less drive bays
- Motherboards: Standard ATX, microATX, Mini-ITX
- 8 expansion slots
- Maximum graphics card size: 318 mm (12,5")
- Maximum CPU cooler height: 170 mm (6,7")
- Cooling System: 1 x 120 mm rear TwoCool™ fan / 1 x 140 mm top TwoCool™ fan / 2 x 120 mm front intake fans (optional) / 1 x 120 mm side intake fan (optional) / 1 x 120 mm side exhaust fan behind motherboard (optional)
- Perforated front bezel for maximum air intake
- Water cooling support: top water cooling grommets
- Enlarged CPU cutout
- Front I/O ports: 2 x USB 3.0 with internal motherboard connector / Audio In/Out
- No power supply included
- Unit Dimensions: 513 mm (H) x 229 mm (W) x 471 mm (D) / 20,2" (H) x 9,0" (W) x 18,5" (D)
- Antec Three Hundred Two - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- I/O Connectors
- 2 x USB 3.0 , 1 x audio line-out , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Meshed front panel, CPU cut-out, cable management holes
- Power Device
- No power supply (ATX / PS/2)
- 22.9 cm x 47.1 cm x 51.3 cm
- 6.9 kg
- 3-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 8
- Front Accessible Bays Qty
- 3
- Cooling System
- Rear: 120 mm fan x 1 / TwoCool , Top: 140 mm fan x 1 / TwoCool , Front: 140 mm fan mount x 2 / intake , Side: 120 mm fan mount x 1 / intake , Side: 120 mm fan mount x 1 / exhaust
- Expansion Bays
- 3 (total) / 3 (free) x front accessible - 5.25" x 1/2H , 6 (total) / 6 (free) x internal - 3.5" x 1/3H , 2 (total) / 2 (free) x internal - 2.5"
- Expansion Slots
- 8 x Expansion Slot
- 2 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
- RoHS
- Power Device
- No power supply
- Specification Compliance
- ATX / PS/2
- Max Supported Qty
- 1
- 22.9 cm
- 47.1 cm
- 51.3 cm
- 6.9 kg
- Limited warranty - 3 years
