Anker Soundcore Life Note - Black
Quicklinx: FXJXWS00 Mfr#: A3908G11
Up to 40 Hours of Playtime
A single charge gives you a full 7 hours of listening, while the charging case extends that to 40 hours. When you’re in a rush and need power fast, simply charge for 10 minutes and get up to 1 hour of playtime.
4 Microphones for Crystal-Clear Calls
Each earbud has two microphones with beamforming noise reduction and cVc 8.0 technology for superior vocal enhancement and background-noise suppression. This ensures your voice is heard clearly on the other end—without interference.
Incredible Sound
Life Note’s graphene drivers oscillate with extreme precision to give your music a wider soundstage with exceptional accuracy and clarity across the entire frequency range. Bass is further enhanced by up to 43% by our exclusive BassUp technology which analyzes low frequencies in real-time and instantly intensifies them. aptX audio allows you to stream music with CD-like audio quality thanks to lossless transmission between your device and the wireless earbuds.
Water-Resistant
Life Note wireless earbuds boast IPX5-rated protection against liquids. The water-resistant casing allows you to keep your conversation going and the music playing—even if you’re caught in heavy downpours.
One-Step Pairing
Our proprietary PUSH AND GO technology streamlines the setup process so when you remove the wireless earbuds from the charging case, they’ll automatically connect to the last paired device.
  • Up to 40 hours of playtime
    Enjoy 7 hours of playtime on a single charge and extend to 40 hours with the charging case.
  • Crystal-clear calls
    4 microphones with the latest cVc noise reduction technology highlight your voice while reducing background sounds.
  • Expertly tuned sound
    Graphene drivers produce a wider soundstage with exceptional accuracy and clarity.
  • BassUp technology
    Exclusive technology conducts real-time analysis and enhancement of your audio's bass frequencies to add powerful sonic punch.
  • aptX technology
    Your music is transferred at the highest possible quality to preserve the sound and give you an exceptional listening experience with CD-like audio quality.
  • Water-resistant casing
    Life Note's IPX5-rated protection defends your earbuds against liquid damage.
  • One-step pairing
    Life Note wireless earphones use Push and Go technology to automatically connect with the last paired device.
  • Comfortable fit
    Select from a range of EarTips in multiple sizes to find the perfect fit for your ears.
  • USB-C charging
    Charge Life Note's charging case using the included USB-C cable.
  • Bluetooth 5
    An ultra-stable connection between the wireless earphones and your device ensures skip-free streaming of music, podcasts, and more.
  • Mono or stereo
    Effortlessly switch between using a single earbud or both.
Soundcore Life Note - true wireless earphones with mic
True wireless earphones - Bluetooth
Recommended Use
Portable electronics
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Sound Effects
BassUp
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 92 dB
Diaphragm Type
Graphene
Microphone Operation Mode
Beamforming
Microphone Noise Cancelling
Microphones Included
4
18 months warranty
True wireless earphones - Bluetooth - wireless
Recommended Use
Protection
IPX5, water-resistant
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
aptX
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Sound Effects
BassUp
Frequency Response
20 - 20000 Hz
Sensitivity
92 dB
Diaphragm
Graphene
Microphone
Built-in
Beamforming
4
Noise Cancelling
Noise Cancelling Technology
cVc 8.0 (clear Voice capture) by Qualcomm
Charging case
Cable Details
USB-C cable - detachable
IPX5
Headphone battery rechargeable
Run Time (Up To)
7 hour(s)
Run Time Details
Continuous playback: up to 7 hours , Continuous playback (with included charging case): up to 40 hours
Limited warranty - 18 months
