Two built-in microphones with uplink noise cancellation boost clarity by recognizing your voice and filtering out ambient noises to ensure you sound crystal-clear even in noisy spaces. Stereo calls further enhance call quality by allowing you to hear the other person's voice in both earbuds.
Graphene-coated drivers oscillate precisely, enabling Liberty Air to reproduce highly-accurate sound. Every detail of the music, from the deepest bass, to the brightest mids, and lush treble is delivered with extraordinary clarity and no distortion.
The latest Bluetooth 5.0 technology and a FPC antenna create a rock-solid connection for skip-free music. One-Step Pairing ensures that after the initial setup is complete, Liberty Air will automatically connect to your device the moment it's removed from the charging case.
A seamlessly concealed sensor in both the earbuds allows you to effortlessly answer calls or adjust music without reaching for your phone.
Sound with exceptional accuracy and clarity
The diamond-inspired drivers are lightweight, yet rigid for precise sound reproduction and extended treble and bass. -
aptX audio
Ensures lossless sound transfer when streaming media from your device. -
HearID tailored sound
Maps your hearing sensitivity across multiple frequencies to create custom EQ settings for a truly personalized listening experience. -
22 EQ modes
Use the Soundcore App to choose from a vast range of customized settings to get the most out of your favorite genres. -
Crystal-clear calls
4 microphones with the latest cVc noise reduction technology effectively highlight your voice while reducing background sounds. -
Up to 28 hours of playtime
Enjoy 7 hours of playtime on a single charge and extend to 28 hours with the charging case. -
Fast-charging
When you're running short on time, a 10-minute charge will give you 2 hours of listening. -
Wireless charging compatible
Simply place the charging case on a wireless charging pad for convenient charging. -
Water-resistant design
Liberty Air 2's IPX5-rated protection defends your earbuds against rain, sweat, and more. -
Customizable EarTips
Choose from 5 sizes of EarTips to find your perfect fit for enhanced passive noise cancellation and comfort.
- Soundcore Liberty Air 2 - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Black
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.0
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Impedance
- 16 Ohm
- Max Input Power
- 5 mW
- Microphone Noise Cancelling
- Microphones Included
- 4
- Controls
- Volume, power on/off, answer/end, play/pause, next/previous track, reject call, voice assistant
- 18 months warranty
- Product Type
- True wireless earphones - Bluetooth - wireless
- Black
- HearID Technology, Diamond-Coated Driver
- Protection
- IPX5, water-resistant
- Max Operating Distance
- 10 m
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC, aptX
- Bluetooth Version
- Bluetooth 5.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Max Input Power
- 5 mW
- Total Harmonic Distortion (THD)
- 1%
- Impedance
- 16 Ohm
- Diaphragm
- 6 mm
Microphone
- Form Factor
- Built-in
- 4
- Noise Cancelling
Remote Control
- Controls
- Included Accessories
- Charging case (500 mAh), 5 pairs of ear tips (XS, small, medium, large, XL), USB-C charging cable
- Battery
- Headphone battery rechargeable
- Included Qty
- 2
- Capacity
- 55 mAh
- Run Time (Up To)
- 7 hour(s)
- Run Time Details
- Continuous playback: up to 7 hours , Continuous playback (with included charging case): up to 28 hours
- Recharge Time
- 2 hour(s)
- Limited warranty - 18 months
