Completely wireless: Qi certified and packed with more than enough power to charge smartphones, headphones, charging cases and more with up to 10 W power
Hi-speed USB: Simply connect via USB-A or USB-C and charge at a speed of up to 18 W
Power a Full Day
PowerCore is equipped with a 10,000mAh capacity to keep your devices charged for at least a full day. Charge an iPhone 11 or Pixel 4 more than twice, or charge a Galaxy S20 over 1.5 times.
This wireless charger does not feature MagSafe-style magnetic alignment, and therefore is not able to charge the iPhone 13 or 12 series magnetically. The wireless charging feature does not work with the Apple Watch series or Samsung Watch series.
Charge multiple devices
Charge your phone wirelessly while charging up to 2 other devices at the same time via dual USB ports. -
Wireless pass-through charging
When connected to the wall, PowerCore continues to provide wireless-charging to your Qi-enabled devices while recharging itself, so you can wake up to a fully charged phone and pad every morning. -
Non-slip design
Designed with a rubber coating that not only helps to keep your phone in place while charging but also feels great in your hand.
 - Anker PowerCore 10000 wireless power bank - USB - 12 Watt
- Product Type
 - Wireless power bank
 - 60 mm x 92 mm x 22 mm
 - 180 g
 - Black
- Output Connector Type
 - Total 2: USB - on cable: USB-C
- Wireless Charging
- Wireless Charging Standards
 - Qi
- Battery
 - 10000 mAh
- Power Provided
 - 12 Watt
- Cables
 - USB-C to USB-A cable
 - 18 months warranty
- Product Type
- Designed For
 - Tablet, mobile phone
 - 60 mm
 - 92 mm
 - 22 mm
 - 180 g
- Enclosure Colour
 - Black
- Input Connectors
 - 24 pin USB-C
- Input Connectors Qty
 - 1
- Output connectors
 - Total 2: 4 pin USB Type A
- Power Provided
 - 12 Watt
- Detachable Cable Connector Type
 - USB-C
- Wireless Charging
 - Qi
- Capacity
 - 10000 mAh
 - LED power meter
- Included Accessories
 - Carrying pouch
- Cables Included
 - Qi
 - Limited warranty - 18 months
