Anker PowerCore Essential 20000 PD Fabric
Quicklinx: FXKLWS00 Mfr#: A1281H11
The two charging ports provide high-speed charging to a huge range of USB-C and USB devices. The USB-C port supports both input and output. You can charge your devices, and recharge your PowerCore at high speed.
  • Trickle-charging mode
    Provide safe and optimized charging to low-power devices such as Bluetooth earphones and speakers.
  • Comprehensive protection
    A comprehensive safety system combines high-voltage protection, current regulation, temperature control, and more to keep you and your devices safe.
  • Power for the day
    With a high capacity, you can easily keep all of your mobile devices charged up for days on end. You'll wonder how you ever spent so much time plugged into the wall.
  • Premium design
    With a sleek exterior and an LED light wheel to display battery level, PowerCore Essential 20000 PD is premium both inside and out.
Anker PowerCore Essential 20000 PD power bank - USB, 24 pin USB-C - 18 Watt
Power bank
7.37 cm x 15.7 cm x 2.03 cm
345.5 g
Output Connector Type
Total 2: USB, 24 pin USB-C
Fast Charge Technology
Power Delivery, Qualcomm Quick Charge
20000 mAh
Power Provided
18 Watt
Cables
USB-C cable
18 months warranty
Power bank
7.37 cm
15.7 cm
2.03 cm
345.5 g
Input Connectors
24 pin USB-C
Input Connectors Qty
1
Output connectors
Total 2: 4 pin USB Type A, 24 pin USB-C
Power Provided
18 Watt
Blue LEDs, PowerIQ Technology, USB-C combined I/O port
20000 mAh
Recharge Time
6.5 hour(s)
Carrying pouch
USB-C cable
Limited warranty - 18 months
