Anker Nebula Vega Portable Projector
Quicklinx: GFXCWS00 Mfr#: D2121G11
Enjoy portable big screen entertainment with the Nebula Vega. With Full HD clarity, 500 lumens brightness, it also boasts dual stereo speakers and Android TV apps. It keeps going for up to 3 hours of entertainment with a rechargeable battery, and features Keystone correction and Digital Zoom for precise projection.
Cinematic visuals
Enjoy fantastic 1080p Full HD entertainment on a projected screen up to 120 inches size. With brightness of 500 ANSI Lumens, and supporting HDR, everything you watch and play is packed with rich detail and vivid colour.
Dolby Digital Plus
Hear every whisper, explosion, and song with great clarity with Dolby Digital Plus sound through the Vega's dual 4W speakers. The Vega can even be used as a portable wireless speaker thanks to built-in Bluetooth.
Wireless freedom
With Vega's built-in rechargeable battery, you can recreate the sights and sounds of the cinema anywhere you want. Get up to 3 hours of power on a single charge, more than enough to have a good binge of your favourite TV series.
Android apps
You can choose from more than 5,000 apps with Android TV 9, including YouTube, Hulu, and many more. And you can mirror content from your smartphone or other smart devices (Copyrighted content cannot be mirrored or screencast).
Adjustable
With a built-in stand, the Vega is easy to adjust (up to 13 degrees), without the need for a tripod or separate stand..
Nebula Vega Portable - DLP projector - portable - 802.11a/b/g/n/ac wireless / Bluetooth 4.2
DLP projector - 1080p
Brightness
500 ANSI lumens
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Bulb type
LED
Bulb life cycle
Up to 30000 hour(s)
Video Input
IEEE 802.11a/b/g/n/ac wireless / Bluetooth 4.2 - MPEG-4, AVI, WMV, MOV, DAT, MKV
Speakers
Speaker(s) - integrated
19.2 cm x 19.2 cm x 5.9 cm
1.4 kg
1-year warranty
802.11a/b/g/n/ac, Bluetooth 4.2
Projector
Brightness
500 ANSI lumens
Image Size
318 cm
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Bulb type
LED
Bulb life cycle
Up to 30000 hour(s)
Controls & Adjustments
Keystone correction
MP3 playback, OGG playback, FLAC playback, auto focus, WMA playback, HDR10 compatibility, Dolby Digital Plus
Lens
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-40 / +40
Horizontal Keystone Correction
-40 / +40
Video Input
Video Interfaces
HDMI
Digital Video Format
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, IEEE 802.11a, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Media Player
ARM Cortex-A53
Graphics Processing Unit
ARM Mali-G31
Operating System
Android TV 9.0
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
4 Watt
Speakers
2 x right / left channel
1 x HDMI - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB (power only)
Wireless remote control, PD charger
1 x USB-C cable
20000 mAh
Run Time (Up To)
3 hour(s)
Recharge Time
3 hours
19.2 cm
19.2 cm
5.9 cm
1.4 kg
Limited warranty - 1 year
Sound Emission
30 dB
