The second generation of Nebula's award winning portable cinema. Mars II takes the dual 10W speakers and compact design of Mars and takes it to a whole new level. With extended playtime, Android 7.1, and single-second autofocus, Mars II creates a private theater just for you.
Sensational clarity
Experience your favorite content in a whole new light. 300 ANSI lm brightness and 720p DLP IntelliBright technology combine to create a crisp, clear picture. -
Stunning sound
Dual 10W audio drivers generate cinematic stereo sound and deep pounding bass. -
Worldwide viewing
Make the whole world your screen with Mars II portable projector. The 1-second autofocus and manual horizontal/vertical (±40°) keystone correction work together to create a sharp and stable image - no matter the surface. -
Binge-watch in style
Watch YouTube, Netflix, and more wherever you go on Mars II movie projector. Seamlessly display your favorite Android 7.1 content for endless hours of entertainment.
- Nebula Mars II - DLP projector - portable
- DLP projector - 720p
- Built-in Devices
- Battery
- Brightness
- 300 ANSI lumens
- Contrast Ratio
- 1000:1
- Resolution
- 1280 x 720
- Native Aspect Ratio
- 16:9
- Bulb life cycle
- Up to 30000 hour(s)
- Video Input
- - DivX, MPEG-4 SP, MPEG4 ASP, H.264, H.263, HEVC, H.265, VP8
- Storage Capacity
- 8 GB
- Speakers
- Speaker(s) - integrated
- 57 Watt
- 12.2 cm x 17.8 cm x 13.8 cm
- 1.483 kg
- 1-year warranty
- Built-in Devices
- Battery
- Networking
- 802.11a/b/g/n, Bluetooth 4.0
Projector
- Brightness
- 300 ANSI lumens
- Contrast Ratio
- 1000:1
- Image Size
- 76.2 cm - 381 cm
- Throw Ratio
- 1.2:1
- Resolution
- 1280 x 720
- 16:9
- Bulb life cycle
- Auto focus, rear projection, Wi-Fi screen mirroring, Bluetooth speaker mode
Lens
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Video Interfaces
- HDMI
- Digital Video Format
Media Player
- Processor
- ARM Cortex-A7
- RAM
- 1 GB
- Storage Capacity
- 8 GB
- Operating System
- Android OS 7.1
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
- 1 x USB 2.0 - 4 pin USB Type A , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-out
- Included Accessories
- Remote control, power adapter
- Power Source
- AC / battery
- 57 Watt
- Power Consumption Stand by
- 0.5 Watt
- Capacity
- 12500 mAh
- Run Time (Up To)
- 4 hour(s)
- Recharge Time
- 3 hours
- 12.2 cm
- 17.8 cm
- 13.8 cm
- 1.483 kg
- Limited warranty - 1 year
- 0 °C
- 35 °C
- 15 - 85% (non-condensing)
Anker Nebula Mars 2 Portable Projector
