Anker MagGo 622 Magnetic Wireless Portable Charger 5K Black
Quicklinx: GSR1WS00 Mfr#: A1611G11
Colours:
  • Prop It Up: Features a versatile built-in foldable kickstand that keeps your iPhone 13/12 upright for a comfortable viewing angle.
  • Strong and Snappy: The super-strong magnet snaps magnetically into place to ensure perfect alignment and an efficient charge.
  • Slim and Compact: The sleek and slim design is only 0.5 inch (12.8 mm) thin, so you can single-handedly take calls, selfies, and more.
  • From Small to Smaller: Anker's new Mini Cell technology reduces the size of the overall battery without compromising power and charging efficiency.
  • What You Get: Anker 622 Magnetic Battery (MagGo), 23.6 inch (60 cm) USB-C to USB-C cable, welcome guide, worry-free 24-month warranty, and friendly customer service.
To Hold or to Fold
The magnetic portable charger holds your iPhone 13/12 in place while charging and combines it with a kickstand that can unfold to function as a phone stand.
Two-Way Charge
Consisting of USB-C input and output ports, you can now quickly recharge the portable charger or power up any compatible USB-C devices.
Safety First
Anker's exclusive MultiProtect technology comes with advanced safety features like temperature control, overload protection, and more to let you charge with zero worries.
Compatibility:
iPhone 13 / iPhone 13 Pro / iPhone 13 Pro Max / iPhone 12 / iPhone 12 Pro / iPhone 12 Pro Max with a magnetic phone case.
  • For best results, use a 12W power adapter (not included).
  • Not compatible with non-magnetic phone cases, such as OtterBox defender cases.
  • Magnetic and metal attachments such as cards, keys, and pop grips will interfere with charging.
  • The magnetic charge provides up to 7.5W maximum power.
  • When the portable charger is charging or discharging, some heat may be generated due to energy loss during transmission. This is a normal occurrence.
  • To hold or to fold
    The magnetic portable charger holds your iPhone in place while charging and combines it with a kickstand that can unfold to function as a phone stand.
  • Loaded with power
    For its modest size that fits in the palm of your hand, the 5000mAh capacity magnetic portable charger is able to provide 17 hours of extended use.
  • Two-way charge
  • Safety first
Anker 622 (MagGo) wireless charging stand / power bank - 24 pin USB-C - 7.5 Watt
Wireless charging stand / power bank
Mobile phone
6.55 cm x 10.5 cm x 1.28 cm
140 g
Interstellar grey
Output Connector Type
24 pin USB-C - on cable: USB-C
Wireless Charging
5000 mAh
Power Provided
7.5 Watt
Cables
USB-C to USB-C cable - 60 cm
Apple iPhone 12, 12 mini, 12 Pro, 12 Pro Max, 13, 13 mini, 13 Pro, 13 Pro Max
Mobile phone
6.55 cm
10.5 cm
1.28 cm
140 g
Enclosure Colour
Interstellar grey
Input Connectors
24 pin USB-C
Output connectors
24 pin USB-C
Power Provided
7.5 Watt
Detachable Cable Connector Type
USB-C
Wireless Charging
MagSafe Compatibility
Built-in foldable stand, built-in magnets, MultiProtect, 7.5W wireless output
5000 mAh
Battery level indicator
