Anker eufy Video Doorbell 2K (Battery-Powered) with HomeBase 2
Quicklinx: G02CWS00 Mfr#: E82101W4
Type: Doorbell kit
The built-in Sony 2K sensor and professional-grade lens allow you to view activity in picture-perfect resolution. See visitors in sharp detail as they approach your door.
Designed to protect your home as well as your wallet, eufy security products are one-time purchases that combine security with convenience. All your data is stored locally meaning you will never have to pay for cloud storage.
  • 2.5x the Clarity: The built-in Sony 2K sensor and professional-grade lens allow you to view activity in picture-perfect resolution. See visitors in sharp detail as they approach your door.
  • No Monthly Fee: Designed to protect your home as well as your wallet, eufy Security products are one-time purchases that combine security with convenience. All your data is stored locally meaning you will never have to pay for cloud storage.
  • Dual Power Options: Half a year of coverage from one charge or non-stop power supply via a wired connection.
  • Expanded Field of View: The increased 4:3 Aspect Ratio ensures you get a head-to-toe view of anyone who approaches and gives you the perfect viewing angle every time.
  • Next-Level Detection: Have total control over what is detected through the use of the motion sensor, smart human detection, and activity zones. Receive real-time alerts when anyone approaches so that you never miss a delivery or keep guests waiting.
  • Kristallklare Ansicht
    HD-Auflösung in Kombination mit fortschrittlicher Verzerrungskorrektur sowie WDR Technologie garantiert Ihnen 2,5-fache Klarheit aller Aufzeichnungen.
  • 180 Tage Akkulaufzeit
    Nach nur einem Aufladen dient Ihnen die eufy Video-Türklingel ein halbes Jahr lang und lässt sich blitzschnell wieder aufladen.
  • Wetterfest nach IP65
    Hält extremen Wetterlagen im Bereich von -20°C bis 50°C mühelos stand, der deutsche Winter kann kommen!
  • Zero Installation
    Einfach Befestigung anbringen und Video-Türklingel einrasten lassen - fertig. Ganz ohne komplizierter Verkabelung.
Eufy Security Video Doorbell - doorbell kit - Wi-Fi
Doorbell kit
Functions
Camera
Power Source
Hardwired, battery
Package Content
Base station, doorbell
Wireless - Wi-Fi
Frequency Band
2.4 Ghz
Camera
Max Resolution 2560 x 1920 - audio
1-year warranty
5.4 cm x 14 cm x 2.8 cm
Doorbell kit
Functions
Camera
Power Source
Hardwired, battery
Package Content
Wireless - Wi-Fi
Frequency Band
2.4 Ghz
Camera
Audio Support
Max Digital Video Resolution
2560 x 1920
Video Modes
2K
2-way voice communication, motion detection
Flash Memory
Installed Size
16 GB
Battery Lifetime
6 months
Warranty
1-year warranty
5.4 cm
14 cm
2.8 cm
500 g
Shipping Width
11 cm
Shipping Depth
20.6 cm
Shipping Height
18.4 cm
Shipping Weight
1.19 kg
Type: Doorbell kit
Brand: Anker
Stock Status: While stocks last
Stock Status: Clearance
