Anker Eufy Smart Scale P1 Black
Quicklinx: G5K7WS00 Mfr#: T9147011
Select:
  • P1 Black
Smart Scale with Bluetooth, Large LED Display, 14 Measurements, Weight/Body Fat/BMI/Fitness Body Composition Analysis, Auto On/Off, Auto Zeroing, Tempered Glass Surface, lbs/kg
  • HOLISTIC HEALTH: Instantly learn 14 insightful measurements of your body's health, such as Weight, Body Fat, BMI, Bone Mass, Muscle Mass, and more.
  • USE WITH 3RD-PARTY APPS: Track your measurements on Apple Health, Google Fit, and Fitbit.
  • ACCURACY IMPROVED BY 10%: Two pairs of super-sensitive G-shaped sensors ensure more precise measurements compared to other sensor types.
  • FOR THE WHOLE FAMILY: Track the health trends of up to 16 users from one account, and the large LED display is easy to read for all ages.
  • WHAT YOU GET: Smart Scale P1, AAA batteries x3, Quick Start Guide, User Manual, and our worry-free 15-month warranty.
  • No sharp corners
    The rounded-glass top plate safeguards you from bumping into pointed edges.
  • Form and function
    The anti-slip top plate and low, stable design ensure stability when you step on.
  • Hassle-free conversions
    Switch from pounds to kilograms and back in one second.
  • No second guessing
    An ITO coating is layered on the surface of Smart Scale to ensure precise measurements every time you step on.
  • Instant Bluetooth connection
    Fast wireless data transfer means you can view your measurements in seconds.
  • Know your body
    See all the historical data of your progress and health trends with ease. Note: Do not use this device if you are wearing a pacemaker or other medical devices inside your body.
  • Unique users
    Eufy Smart Scale P1 is intelligent enough to match measurements to the correct user profile, automatically. Note: Do not use this device if you are pregnant.
  • Easy to Set up
    Just connect pair Smart Scale with the EufyHome app on your smartphone, step on, and see your results. Your data is encrypted before being transmitted via Bluetooth from Smart Scale to your smartphone to ensure security and privacy in the EufyLife app; it is only used to calculate your physical parameters and will never be used for other purposes.
  • Holistic health
  • Use with 3rd-party apps
  • Accuracy improved by 10%
  • For the whole family
Eufy Smart Scale P1 - bathroom scales - black
Bathroom scales - electronic
Maximum Weight
180 kg
Maximum Weight (US)
397 lbs
28 cm x 28 cm x 2.4 cm
1.5 kg
15 months
Category
Personal health
Scales
Maximum Weight
180 kg
Maximum Weight (US)
397 lbs
Weight Units
Kg, lb
Graduation
0.1 kg
Graduation (US)
0.1 lbs
Measuring Functions
Body water percentage, body fat percentage, body mass index (BMI), muscle mass, bone mass, basal metabolic rate (BMR), fitness assessment, visceral fat, metabolic age, protein, body fat mass, lean body mass
Instant On
Non-Slip Platform
Platform Size
28x28cm
Platform Material
Tempered glass
Settings, Controls & Indicators
Indicators
Low battery, overload, fault indicator
14 results memory
Smartphone Compatible
Display
LED display
Internet of Things (IoT)
Communications Technology
Bluetooth
Compatible Application
Apple Health, Google Fit, Fitbit, EufyLife App
Supported Host Device Platform
iOS, Android
AAA battery x 3
Power Source
Battery Form Factor
AAA
Required Battery Qty
3
Auto Shut Off
28 cm
28 cm
2.4 cm
1.5 kg
Width (Shipping)
31.5 cm
Depth (Shipping)
31.8 cm
Height (Shipping)
4.1 cm
Weight (Shipping)
1.86 kg
Warranty
15 months
