Measurements Made Easy for All
- HOLISTIC HEALTH: Instantly learn 12 insightful measurements of your body's health.
- FREE EUFYLIFE APP & 3RD-PARTY APPS: Track your measurements on Apple Health, Google Fit, and Fitbit.
- ACCURACY IMPROVED BY 10%: Two pairs of super-sensitive G-shaped sensors ensure more precise measurements.
- FOR THE WHOLE FAMILY: Track the health trends of up to 16 users from one account,recognise each member automatically.
- WHAT YOU GET: Smart Scale C1, AAA batteries x3, Quick Start Guide, User Manual, and our worry-free 15-month warranty.
No sharp corners
The rounded-glass top plate safeguards you from bumping into pointed edges. -
Form and function
The anti-slip top plate and low, stable design ensure stability when you step on. -
Hassle-free conversions
Switch from pounds to kilograms and back in one second. -
Instant Bluetooth connection
Fast wireless data transfer means you can view your measurements in seconds. -
Know your body
See all the historical data of your progress and health trends with ease. -
Unique users
Eufy Smart Scale C1 is intelligent enough to match measurements to the correct user profile, automatically.
- Eufy Smart Scale C1 - bathroom scales - white
- Product Type
- Bathroom scales - electronic
- Maximum Weight
- 180 kg
- Maximum Weight (US)
- 397 lbs
- White
- 28 cm x 28 cm x 2.3 cm
- 1.5 kg
- 15 months
- Product Type
- Category
- Personal health
- White
Scales
- Maximum Weight
- 180 kg
- 397 lbs
- Weight Units
- Kg, lb
- Graduation
- 0.1 kg
- Graduation (US)
- 0.1 lbs
- Measuring Functions
- Body water percentage, body fat percentage, body mass index (BMI), muscle mass, bone mass, basal metabolic rate (BMR), visceral fat, body fat mass, lean body mass
- Instant On
- Non-Slip Platform
- Platform Size
- 28x28cm
- Platform Material
- Tempered glass
Settings, Controls & Indicators
- Indicators
- Low battery
- Memory
- 16 user memory
- Smartphone Compatible
Display
- LED display
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Communications Technology
- Bluetooth
- Compatible Application
- Apple Health, Google Fit, Fitbit, EufyLife App
- Supported Host Device Platform
- iOS, Android
- Included Accessories
- AAA battery x 3
- Power Source
- Battery
- Battery Form Factor
- AAA
- Required Battery Qty
- 3
- Auto Shut Off
- 28 cm
- 28 cm
- 2.3 cm
- 1.5 kg
- Warranty
- 15 months
