Anker Eufy Security Motion Sensor add-on
Quicklinx: G73BWS00 Mfr#: T8910021
Type: Motion sensor
19 In Stock
£24.99 ex VAT
£29.98 inc VAT
eufy Security features a powerful battery that provides long-lasting power for round-the-clock security. To prevent your playful pets from accidentally triggering the motion sensor, you can adjust the sensitivity so that it only triggers when human-sized intruders are detected.
  • Protection that lasts
    The included battery provides ling-lasting power for round-the-clock security.
  • Extensive coverage
    Detects motion within a 100° radius and up to 30 feet away - more than enough to secure an entire room of your home.
  • Protects you, your family, and your privacy
    Every eufy Security product is engineered to ensure your data is kept private. Keep a secure record of everything that happens around your home.
  • Customizable detection
  • Part of the family
    Adding the motion sensor to your existing security system is a breeze. Once installed, pair the device via the eufy Security app. Then, press the button on the motion sensor, and HomeBase will add the sensor to your existing security setup.
Eufy Security - motion sensor - Wi-Fi - white
Motion sensor
Power Source
Wireless - Wi-Fi
Adjustments
Detection sensitivity
White
1-year warranty
5.62 cm x 2.2 cm x 5.62 cm
Motion sensor
Power Source
Wireless
Adjustments
In app notification
Motion Sensor
Detection Range
9.14 m
Detection Angle
100 degree(s)
Battery Included
Required Qty
1
Battery Lifetime
2 years
White
Warranty
1-year warranty
5.62 cm
2.2 cm
5.62 cm
70 g
Shipping Width
14.2 cm
Shipping Depth
10.5 cm
Shipping Height
3.8 cm
Shipping Weight
220 g
Type: Motion sensor
Brand: Anker
