Anker Eufy Security Entry Sensor
Quicklinx: G73CWS00 Mfr#: T89000D4
Type: Door and window sensor
£15.19 ex VAT
£18.22 inc VAT
This Entry Sensor protects your doors and windows from break-ins.
  • 2-year battery life
    One battery provides monitoring for 730 days.
  • Suitable for doors and windows
    Small and compact design fits onto any door or window frame.
  • 100-decibel siren
    If a forced entry is detected, a siren as loud as a jackhammer will be triggered on HomeBase, and you'll be notified instantly on your smartphone.
  • Easy installation
    Just peel off the mounting tape and stick the sensor onto the door or window you want to monitor.
Eufy Entry Sensor - door and window sensor - white
Power Source
Wireless
Siren Sound Level
100 dB
White
2.8 cm x 7.4 cm x 2.2 cm
Power Source
Wireless
Siren Sound Level
100 dB
LED indicator
CR123A
Battery Included
Required Qty
1
Battery Lifetime
2 years
Screws
White
FCC, Directive 2014/53/EU
2.8 cm
7.4 cm
2.2 cm
120 g
Shipping Width
3 cm
Shipping Depth
7.4 cm
Shipping Height
11 cm
Shipping Weight
3.13 kg
Brand: Anker
