Brand
Anker Eufy RoboVac X8
Quicklinx: GRYYWS00 Mfr#: T2262V11
Type: Smart Vacuum
Compatible With: Alexa, Google Assistant
£416.66 ex VAT
£499.99 inc VAT
Innovative eufy technology has doubled the suction power to achieve a deeper level of clean. Two turbines, each generating up to 2000 Pa of intense suction, efficiently increases cleaning power. Leave the floors to RoboVac X8 Series so you can focus on the more important things. Double down on power, double down on life.
  • Twin-Turbine technology
    Each turbine offers 2000 Pa of suction power, increasing overall airflow by 80% so your house can go back to looking its best. Clean up to 57.6% more pet hair with the immense power of the Twin Turbines.
  • iPath laser navigation
    By intelligently memorizing your house environment, RoboVac can quickly build a virtual map to follow for the most efficient cleaning route, without needing you to manually map it out.
  • AI.Map 2.0 technology
    Guided by intelligently-generated, multi-floor maps, RoboVac will know where it's cleaning, whether it's on the first floor, in the basement, or in the attic. Customize cleaning areas, no-go zones, and more via the app.
  • UltraPack dust compression
    The sheer force at which the dust is sucked in will tightly pack the dust box, increasing the volume utilization rate by 127% and decreasing the number of trips you need to take to empty it.
  • You're in charge
    Control RoboVac via the app. Select rooms to clean, no-go zones, view maps, see how much your RoboVac has cleaned, and more.
  • Rolling brush to the rescue
    Get in between tiles and cracks to thoroughly clean the floor with a specially designed rolling brush that effectively lifts dirt for the Twin Turbines to catch.
  • Extended runtime
    Sit back and relax as RoboVac cleans 1 m2 (10.76 ft2) every minute for up to 180 minutes per charge, leaving behind stunning floors.
  • Tap and go
    Easily vacuum accidental messes. Choose a spot that you want to specifically clean and watch RoboVac get to work.
  • Voice-activated control
    Compatible with the Google Assistant and Alexa. Use voice control assistants to start a clean whenever you want.
Eufy RoboVac X8 - vacuum cleaner - robotic
Vacuum cleaner
Cleaner Type
Robotic
Compatible Floor Type
General purpose
Cleaning Method
Dry
Communications Technology
Wi-Fi
Intelligent Assistant
Google Assistant, Alexa
Dust Collection
Bagless
Operating Autonomy
180 min
Sound Pressure Level (SPL)
60 dB
34.5 cm x 34.5 cm x 9.72 cm
3.5 kg
1 year
Vacuum cleaner
Cleaner Type
Robotic
Vacuum Cleaner Type
General purpose
Cleaning Method
Dry
Dust Collection
Bagless
Dust Capacity
0.6 litres
Suction Pressure
4 kPa
Room Navigation
Special Features
Adjustable suction
Pet Hair Removal
Settings, Controls & Indicators
Smartphone Compatible
Internet of Things (IoT)
Wi-Fi
60 dB
Power Type
Rechargeable batteries
Operating Autonomy
180 min
Lithium Ion
Battery Voltage
24 V
Battery Capacity
5200 mAh
Full Charge Time
5 hrs
34.5 cm
34.5 cm
9.72 cm
3.5 kg
Width (Shipping)
42 cm
Depth (Shipping)
46.2 cm
Height (Shipping)
16.3 cm
Warranty
1 year
Type: Smart Vacuum
Brand: Anker
