Innovative eufy technology has doubled the suction power to achieve a deeper level of clean. Two turbines, each generating up to 2000 Pa of intense suction, efficiently increases cleaning power. Leave the floors to RoboVac X8 Series so you can focus on the more important things. Double down on power, double down on life.
Twin-Turbine technology
Each turbine offers 2000 Pa of suction power, increasing overall airflow by 80% so your house can go back to looking its best. Clean up to 57.6% more pet hair with the immense power of the Twin Turbines. -
2-in-1 vacuum and mop
Mop while you vacuum for a more efficient cleaning schedule and squeaky clean floors. RoboVac can provide up to 180 minutes of vacuuming, while the extra-large 250 ml water tank holds enough water for about 140 minutes of mopping. -
iPath laser navigation
By intelligently memorizing your house environment, RoboVac can quickly build a virtual map to follow for the most efficient cleaning route, without needing you to manually map it out. -
AI.Map 2.0 technology
Guided by automatically-generated, multi-floor maps, RoboVac will know where to clean, whether it's on the first floor, in the basement, or in the attic. Customize cleaning areas, no-go zones, and more via the app. -
Big tank
At 250 ml, the tank holds enough water to mop for up to 140 minutes while vacuuming simultaneously. Just remove the tank, fill it with water, and reinstall it when you're ready to clean. -
You're in charge
Control RoboVac via the app. Select rooms to clean, no-go zones, view maps, see how much your RoboVac has cleaned, and more. -
Rolling brush to the rescue
Get in between tiles and cracks to thoroughly clean the floor with a specially designed rolling brush that effectively lifts dirt for the Twin Turbines to catch. -
Extended runtime
Sit back and relax as RoboVac cleans 1 m2 (10.76 ft2) every minute for up to 180 minutes per charge, leaving behind stunning floors. -
Tap and go
Easily vacuum accidental messes. Choose a spot that you want to specifically target and watch RoboVac go and spot clean. -
Voice-activated control
Compatible with the Google Assistant and Alexa. Use voice control assistants to start a clean whenever you want.
- Eufy RoboVac X8 Hybrid - vacuum cleaner - robotic
- Product Type
- Vacuum cleaner
- Cleaner Type
- Robotic
- Compatible Floor Type
- General purpose
- Cleaning Method
- Dry, wet
- Communications Technology
- Wi-Fi
- Intelligent Assistant
- Google Assistant, Alexa
- Dust Collection
- Bagless
- Operating Autonomy
- 180 min
- Sound Pressure Level (SPL)
- 60 dB
- 34.5 cm x 34.5 cm x 9.72 cm
- 3.9 kg
- 1 year
- Product Type
- Vacuum cleaner
- Cleaner Type
- Robotic
- Vacuum Cleaner Type
- General purpose
- Cleaning Method
- Dry, wet
- Dust Collection
- Bagless
- Dust Capacity
- 0.4 litres
- Tank Capacity
- 0.25 litres
- Suction Pressure
- 4 kPa
- Room Navigation
- Pet Hair Removal
Settings, Controls & Indicators
- Smartphone Compatible
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Wi-Fi
- 60 dB
- Power Type
- Rechargeable batteries
- 180 min
- Battery
- Lithium Ion
- Battery Voltage
- 24 V
- Battery Capacity
- 5200 mAh
- Full Charge Time
- 5 hrs
- 34.5 cm
- 34.5 cm
- 9.72 cm
- 3.9 kg
- Width (Shipping)
- 42 cm
- Depth (Shipping)
- 46.2 cm
- Height (Shipping)
- 17.5 cm
- Warranty
- 1 year
