Anker eufy RoboVac G30 Verge Black
Quicklinx: FVXFWS00 Mfr#: T2252K11
Select:
  • G30
Robot Vacuum with Smart Dynamic Navigation 2.0, 2000Pa Strong Suction, Wi-Fi, Works with Alexa, Carpets and Hard Floors.
  • Smart Dynamic Navigation 2.0: With the Path Tracking Sensor, Smart Dynamic Navigation 2.0 allows for purposeful cleaning when compared to random path robotic vacuums.
  • 2000Pa of Hard-Hitting Suction: The ultra-strong 2000Pa of suction power ensures more debris is picked up across all surfaces giving you noticeably cleaner floors.
  • App Control with Cleaning History: Complete all your cleaning needs right from your smartphone. When the job is done check-out where and when your RoboVac cleaned.
  • BoostIQ Technology: Automatically increases suction power within 1.5 seconds when extra vacuuming strength is needed—so you get the best clean.
  • What You Get: RoboVac G30, Charging Base, AC Power Adapter, 2 Side Brushes, Additional Unibody Filter, Cleaning Tool, 5 Cable Ties, Welcome Guide, and our Worry-free 12-month Warranty.
  • Home Mapping
    With the Path Tracking Sensor, Home Mapping allows for purposeful cleaning across all surfaces when compared to random path robotic vacuums.
  • 2000Pa of hard-hitting suction
  • App control with cleaning history
  • Set boundary strips
    Exclude your kid's play area or your pet's bed. RoboVac uses specialized dual-Hall Sensors to detect the Boundary Strips you set, ensuring it only cleans the areas required.
    The refined Gyro-navigation Technology and all-new Path Tracking Sensor allow RoboVac to clean with purpose like never before.
  • Packs-a-punch
    2000Pa of hard-hitting suction power means that RoboVac won't miss a speck as it glides from room to room.
  • Total control over your clean
    Give detailed commands right from the app or control via voice assistant. When the task is complete, check the cleaning history to see where and for how long your RoboVac cleaned. Helpful voice reminders provide you with guidance and updates so you always know what is going on.
  • BoostIQ and hands-free control
    RoboVac possesses BoostIQ technology which automatically increases suction power when extra vacuuming strength is needed. With multiple cleaning modes and auto-clean scheduling RoboVac ensures an effortless, thorough clean while you relax.
  • Improved cleaning
    Refined from the inside and out to provide quiet vacuuming with zero hassle, RoboVac cleans with the equivalent sound of a microwave. Reduced height of only 2.85" allows for cleaning under low-lying furniture with ease.
Eufy RoboVac G30 - vacuum cleaner - robotic
Vacuum cleaner
Cleaner Type
Robotic
Compatible Floor Type
General purpose
Cleaning Method
Dry
Control Elements
Touchpad
Communications Technology
Wi-Fi
Dust Collection
Bagless
Operating Autonomy
110 min
Power Consumption
40 W
32.5 cm x 32.5 cm x 7.2 cm
2.6 kg
1 year
Vacuum cleaner
Cleaner Type
Robotic
Vacuum Cleaner Type
General purpose
Carpet, hardwoods, laminate, hard floor, tile
Cleaning Method
Dry
Dust Collection
Bagless
Dust Capacity
0.6 litres
Suction Pressure
2 kPa
Room Navigation
Special Features
Sensor technology
Settings, Controls & Indicators
Control Elements
Touchpad
Scheduling Presets
Smartphone Compatible
Internet of Things (IoT)
Wi-Fi
Included Tools
Side brush (2x)
Boundary marker , Charging dock , Power adapter , Cleaning tool , 5 x cable ties
Power Type
Rechargeable batteries
Operating Autonomy
110 min
Lithium Ion
Battery Voltage
14.4 V
Battery Capacity
2600 mAh
Full Charge Time
6 hrs
Power Consumption
40 W
32.5 cm
32.5 cm
7.2 cm
2.6 kg
Warranty
1 year
