Anker Eufy HomeVac H11 Pure Blue
Quicklinx: G5K8WS00 Mfr#: T2520G31
Cordless Handheld Vacuum Cleaner, Ultra-lightweight 1.3lbs, 5500Pa Suction Power, Ozone Purification, USB Charging, For Home Cleaning.
  • Lightweight and Compact: Completely cordless, weighing just 1.3lbs, and roughly the size of a wine bottle. Cleaning is made effortless and storage is made simple.
  • Dust-Devouring Suction: With 5500Pa of power, you can suck up every spec in seconds when everyday mess is made.
  • Every Nook and Cranny Covered: Use the 2-in-1 crevice tool to reach into the deepest corners of your sofa or under low-lying furniture.
  • Freshen Up: Eradicate odors created by sports equipment or well-used shoes by activating the Ozone feature in the immediate vicinity.
  • What’s in the box:eufy HomeVac H11 Pure, 2-in-1 Crevice Tool, USB to Micro USB Cable.
  • Seamless storage
    Completely cordless, weighing just 1.3 lbs., and roughly the size of a wine bottle. Cleaning is made effortless and storage is made simple.
  • One-pass suction power
    The dust-devouring 5500Pa suction power instantly cleans up everyday mess.
  • Freshen up
    Eradicate odors and freshen up small areas simply by tapping the O3 switch.
  • Designed for control and mobility
    The ergonomic, non-slip design allows for comfortable and precise handling.
  • Suitable for delicate surfaces
    Use the brush on the 2-in-1 crevice tool when a softer touch is required.
  • Washable high-efficiency filter
    For simple maintenance and efficient cleaning.
Eufy HomeVac H11 Pure - air purifier/vacuum cleaner - cordless - handheld - blue
Air purifier/vacuum cleaner - cordless
Cleaner Type
Handheld
Compatible Floor Type
General purpose
Cleaning Method
Dry
Maximum Suction Power (Air Watts)
15.2
Dust Collection
Bagless
Operating Autonomy
13 min
Blue
7.4 cm x 7.4 cm x 33.5 cm
600 g
2 years
Cleaner Type
Handheld
Vacuum Cleaner Type
General purpose
Cleaning Method
Dry
Cordless
Dust Collection
Bagless
Filter Type
High-Efficiency filter
Dust Capacity
0.09 litre
15.2
Suction Pressure
5.5 kPa
Special Features
Washable filter
Pet Hair Removal
Blue
Included Tools
2 in 1 crevice tool, brush attachment
USB to micro-USB charging cable
Power Type
Rechargeable batteries
Operating Autonomy
13 min
Lithium Ion
Battery Capacity
2000 mAh
Full Charge Time
2.5 hrs
7.4 cm
7.4 cm
33.5 cm
600 g
Warranty
2 years
