The MCP-108/8-button Massio ControlPad with Knob combines AMX control and a stylish keypad into a single unit that can be mounted in a standard 2 gang back box to provide dedicated room control. Massio ControlPads provide high performance, intuitive usability and modern styling, and are simple to configure exclusively using AMX's Rapid Project Maker software. The MCP-108 shares its controller technology with AMX's flagship NX-series, enabling it to provide the latest networking and security features, along with outstanding processing power.
- AMX Massio MCP-108 button panel - white
- Button panel
- Enclosure Colour
- White
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 15.25 cm x 2.6 cm x 11.9 cm
- 190 g
- Connectivity Technology
- Cable
- Supported Devices
- Home control, AV System
- Input Device
- Keypad
- Buttons Qty
- 8 buttons
- Button panel
- 15.25 cm
- 2.6 cm
- 11.9 cm
- 190 g
- Enclosure Colour
- White
- Cable
- Supported Devices
- Input Device
- Keypad
- Buttons Qty
- 8 buttons
- Programmable, remote confirmation, back-lit buttons, LED indicator, volume control, button labelling, Power over Ethernet, inactivity timer
- RAM
- 256 MB
Network
- Network Protocols Supported
- TCP, IP
- Connector Type
- 1 x USB (mini-USB Type B) , 1 x LAN (RJ-45) , 2 x serial (3 pin terminal) , 2 x serial , 1 x Data input / output (4 pin terminal) , 2 x serial (4 pin terminal)
- Included Accessories
- Labels, mounting bracket, connector, 4 screws
- VCCI, C-Tick, EN55022, EN55024, CISPR 22, RoHS, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE
- 0 °C
- 40 °C
- 5 - 85%
