AMD Sapphire Firepro V3900 1GB DDR3 Dual Link DVI DP
Quicklinx: 9YCQWS00 Mfr#: 31004-26-40A
AMD FirePro V3900 professional graphics enables an exceptional user experience by delivering features and reliability designed to help boost the productivity of professionals working with low to moderate-complexity designs.
The AMD FirePro V3900 professional graphics card is powered by a GPU, backed by 1 GB of fast DDR3 memory, 480 stream processors and support for up to 5 (five) display devices using AMD Eyefinity multi-monitor technology and DisplayPort 1.2 multi-streaming technology.
  • Certified applications
    AMD FirePro graphics accelerators are carefully certified by AMD and leading software vendors for use with the most widely used software applications to help ensure stable, optimized performance, outstanding productivity and unbeaten user experiences professionals demand.
  • 40 nm process technology
    AMD is first to bring to market in the form of the 40 nm processor on the graphic card, It takes more performance and better energy efficiency, and deliver advanced gaming and HD multimedia technologies for the desktop gamers.
  • AMD Eyefinity multi-monitor technology
    AMD Eyefinity technology maximizes your field of view across up to 6 displays, fully engaging your peripheral vision. For professionals this puts you right in the software and for other applications it helps to increase productivity by maximizing your visual workspace so that you can see more windows simultaneously. AMD Eyefinity technology is also ideal for multimedia applications as it allows you to keep several "palettes" or "panels" open over larger workspace whist you edit your images or videos.
  • Full 30-bit display pipeline
    With a full 30-bit display pipeline producing more than one billion colors (10-bit per RGB component). The AMD FirePro is ideally suited for applications that benefit from accurate color reproduction and superior visual quality.
  • AutoDetect technology
    AMD FirePro products incorporate a unique AutoDetect technology. As users open the 3D applications, or move between them, optimized AMD FirePro graphics driver settings are automatically configured for maximum performance, no matter what the user's workflow demands.
  • Low power consumption
    AMD devotes products into the energy saving for the products to provide the customers with more energy-efficient products through product design, protecting the Earth together. Using AMD FirePro workstation graphic card to establish your multi-monitor systems and low-cost electricity idea.
  • Low profile design
    Enables flexible installation in a variety of computing systems, from small form factors to full-height systems.
Sapphire FirePro V3900 - graphics card - FirePro V3900 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD FirePro V3900
1 GB DDR3
Stream Processors
480
Memory Interface
128-bit
Max Resolution
2560 x 1600
DisplayPort , DVI-I (dual link)
API Supported
DirectX 11, OpenGL 4.2, OpenGL 1.1
Package Type
Retail
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD FirePro V3900
Stream Processors
480
Max Resolution
2560 x 1600 at 60 Hz
API Supported
AMD Eyefinity Technology, Shader Model 5.0
Size
1 GB
DDR3 SDRAM
Bus Width
128-bit
Bandwidth
28.8 GBps
Linux, Microsoft Windows Vista / XP / 7
75 Watt
Full-height bracket
1 x DisplayPort-DVI adapter
Package Type
Retail
