AMD HP AMD FIREPRO W4300 4GB GRAPHICS PROMO
Quicklinx: CH6CWS00 Mfr#: T7T58AT
Realize fast throughput, superb visual quality, and outstanding multi-display capabilities for your CAD, Engineering, and Media & Entertainment applications with the single-slot, low profile, low-power AMD FirePro 4300 graphics card with 4 GB GDDR5 memory.
Get support for your professional software with a graphics card that’s optimized and certified for more than 100 different leading workstation ISV applications.
Balance GPU compute and 3D workloads with AMD’s Graphics Core Next (GCN) architecture. Direct Graphics Memory Access (GMA) enables high throughput and low latency data transfers. GeometryBoost improves GPU processing speed of geometry data.
Experience superb visual quality from four DisplayPort 1.2a outputs and drive up to four 4K1 displays natively from a single card. Manage your multi-display screen setup as one display with AMD Eyefinity.
Enjoy low power consumption of <50 watts reinforced by AMD PowerTune, which dynamically monitors and manages the GPU’s power draw to enable higher clock speeds and help improve performance.
The AMD FirePro W4300 is supported on the following HP workstations: Z240, Z440, Z640, Z840.
  • Reliable ISV compatibility
    Get support for your professional software with a graphics card that's optimized and certified for more than 100 different leading workstation ISV applications.
  • Efficient performance
    Balance GPU compute and 3D workloads with AMD's Graphics Core Next (GCN) architecture. Direct Graphics Memory Access (GMA) enables high throughput and low latency data transfers. GeometryBoost improves GPU processing speed of geometry data.
  • Outstanding multi-display support
    Experience superb visual quality from four DisplayPort 1.2a outputs and drive up to four 4K displays natively from a single card. Manage your multi-display screen setup as one display with AMD Eyefinity.
  • Smart power
    Enjoy low power consumption of <50 watts reinforced by AMD PowerTune, which dynamically monitors and manages the GPU's power draw to enable higher clock speeds and help improve performance.
AMD FirePro W4300 - graphics card - FirePro W4300 - 4 GB - Smart Buy
Graphics card - low profile
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD FirePro W4300
4 GB GDDR5
Core Clock
930 MHz
Stream Processors
768
Effective Memory Clock
1500 MHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
6
Interfaces Details
4 x Mini DisplayPort
API Supported
OpenGL 4.4, DirectX 12, OpenCL 2.0
Manufacturer Selling Program
HP Smart Buy
Workstation Z240, Z440, Z640
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD FirePro W4300
Core Clock
930 MHz
Stream Processors
768
Max Resolution
4096 x 2160 at 60 Hz
6
Interfaces Details
API Supported
AMD Eyefinity Technology, AMD PowerTune technology, Shader Model 5.0, Graphics Core Next (GCN), Multi-Stream Technology, FreeSync Technology, Adaptive-Sync, supports up to 4 displays via MST or HBR2
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
1500 MHz
Bus Width
128-bit
Bandwidth
96 GBps
Linux, Microsoft Windows 7 (32/64 bits), Windows 10
50 Watt
HP Smart Buy
HP Workstation Z240, Z440, Z640
