AMD HP AMD FirePro W2100 2GB Graphics
Quicklinx: CH6BWS00 Mfr#: J3G91AT
Power through your small-to-medium complexity product development and video projects with the latest professional-class GPU technology of the AMD FirePro W2100 low profile graphics board.
Reliable ISV compatibility.
Get support for your professional software with a GPU that’s optimized and certified for more than 100 different leading workstation ISV applications.
Smart power.
Realize dynamic GPU power management with AMD PowerTune, which gives you as much or as little power as you need for your applications, and AMD ZeroCore Power.
Twice the views.
Drive dual displays with resolutions up to 4k with two DisplayPort 1.2a outputs.
  • Reliable ISV compatibility
    Get support for your professional software with a GPU that's optimized and certified for more than 100 different leading workstation ISV applications.
  • Smart power
  • Twice the views
AMD FirePro W2100 - graphics card - FirePro W2100 - 2 GB - Smart Buy
Graphics card - low profile
Bus Type
PCI Express 3.0 x8
Graphics Engine
AMD FirePro W2100
2 GB DDR3
Core Clock
630 MHz
Stream Processors
320
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 / DisplayPort: 4096 x 2160 / VGA: 1920 x 1200
Max Monitors Supported
2
Interfaces Details
2 x DisplayPort
API Supported
OpenCL 1.2, DirectX 11.2, OpenGL 4.4, DirectX 12
Manufacturer Selling Program
HP Smart Buy
1-year warranty
Workstation Z4 G4, Z440, Z6 G4, Z640, Z8 G4, Z840
Bus Type
PCI Express 3.0 x8
Graphics Engine
AMD FirePro W2100
Core Clock
630 MHz
Stream Processors
320
Max Resolution
4096 x 2160 at 60 Hz
2
Interfaces Details
2 x DisplayPort
API Supported
AMD PowerTune technology, Shader Model 5.0, Graphics Core Next (GCN), AMD ZeroCore Power technology
Size
2 GB
DDR3 SDRAM
Bus Width
128-bit
Bandwidth
28.8 GBps
Linux, Microsoft Windows 7 (32/64 bits), Windows 8.1 (32/64 bits)
35 Watt
Full-height bracket
HP Smart Buy
Limited warranty - parts and labour - 1 year
HP Workstation Z4 G4, Z440, Z6 G4, Z640, Z8 G4, Z840
