AMD FirePro W9100 16GB GDDR5 PCIe 3.0 x16 6x Mini DisplayPort
Quicklinx: C7L1WS00 Mfr#: 100-505977
Work at an unseen level of detail, speed, responsiveness and creativity with supercomputing-class performance at your fingertips. Tackle extremely complex modeling and simulation projects with speed and agility, or fly through edits, filters and color corrections, and process multiple effects in real time with AMD FirePro W9100 Professional Graphics.
  • 5.24 TFLOPS of peak single-precision floating-point performance
    Helps speed up time required to complete single precision operations used within simulations, video enhancement, signal processing, video transcoding and digital rendering applications where high performance takes precedence over accuracy.
  • Plenty of memory
    Work at a high level of speed and responsiveness. With an extensive memory, users can edit 4K video, layer in multiple effects and color correct, or load massive assemblies and data sets and manipulate them in real time.
  • 4K resolution
    With six mini DisplayPort outputs and support for DisplayPort 1.2, the AMD FirePro W9100 can actually drive up to six 4K displays without DisplayPort 1.2 MST hubs. The ability to run up to six 4K displays lets you visualize every detail of your project in exciting ways. That's nearly 50 million pixels at your command.
  • OpenCL 2.0 support
    Tap into the parallel computing power of modern GPUs to accelerate compute-intensive tasks in leading CAD/CAM/CAE and Media and Entertainment applications that support OpenCL. With 2.62 TFLOPs of peak double-precision floating-point performance, AMD FirePro W9100 is the card to break the 2.0 TFLOPS double-precision barrier. It's expected to support OpenCL 2.03, allowing developers to take advantage of advanced features that give GPUs more freedom to do the work they are designed to do.
  • DirectGMA and SDI support
    Removes CPU bandwidth and latency bottlenecks and optimizes communication between GPUs within a system, as well as with third-party devices like SDI I/O cards. DirectGMA bypasses any need to traverse the host's main memory, reducing CPU utilization and helping to avoid redundant transfers over PCIe, resulting in high-throughput, low-latency data transfers.
  • Framelock/Genlock
    Ensures accurate and consistent video synchronization to external sources or multiple GPUs in different systems.
AMD FirePro W9100 - graphics card - FirePro W9100 - 16 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD FirePro W9100
16 GB GDDR5
Stream Processors
2816
Memory Interface
512-bit
Max Resolution
4096 x 2160
Max Monitors Supported
6
Interfaces Details
6 x Mini DisplayPort
API Supported
DirectX 11.2, OpenGL 4.4, DirectX 12, OpenCL 2.0
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD FirePro W9100
Stream Processors
2816
Max Resolution
4096 x 2160
6
Interfaces Details
API Supported
ATI CrossFire Pro Technology, AMD Eyefinity Technology, AMD PowerTune technology, AMD GeometryBoost Technology, Shader Model 5.0, AMD ZeroCore Power technology, DirectGMA support, Genlock, FreeSync Technology, AMD HD3D Pro support
Size
16 GB
GDDR5 SDRAM
Bus Width
512-bit
Bandwidth
320 GBps
Linux, Microsoft Windows 7, Windows 8.1, Windows 10
Additional Requirements
Internet connection, dual-width x16 graphics slot, 6 pin PCI Express power connector, 8 pin PCI Express power connector
275 Watt
UL, VCCI, C-Tick, BSMI, FCC, RoHS, KCC, WEEE
Limited warranty - 3 years
