AMD FirePro W600 professional graphics is the ideal solution for powering display walls designed to attract, inform and engage audiences or foster collaborative interaction and decision making. It's the powerful, flexible and affordable multi-display professional graphics product the display wall market needs.
AMD FirePro W600 professional graphics is the most powerful solution available for configuring display walls featuring multiple displays - no other single-slot professional graphics card is capable of driving up to six displays, features the excellent graphics memory technology for exceptional multimedia performance and only consumes less power.
DisplayPort technology
DisplayPort can take multi-monitor display walls to new heights - high bit-rate audio, multi-stream transport, higher data bandwidth, multi-stream audio, 4 k x 2 k resolution, and more. -
AMD FirePro professional graphics for display walls
Delivering the performance, high display density and dedicated features needed to configure multimedia rich multi-monitor display walls. -
AMD Eyefinity Multi-Display technology for display walls
Increase display density and lower TCO with AMD Eyefinity enabled AMD FirePro professional graphics cards.
- AMD FirePro W600 - graphics card - FirePro W600 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD FirePro W600
- Memory
- 2 GB GDDR5
- Max Resolution
- 4096 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 / DisplayPort: 4096 x 2160 / VGA: 1920 x 1200
- Max Monitors Supported
- 6
- Interfaces Details
- 6 x Mini DisplayPort
- API Supported
- OpenGL 4.4, DirectX 12
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- AMD FirePro W600
- Max Resolution
- 4096 x 2160 at 60 Hz
- 6
- API Supported
- AMD PowerTune technology, AMD ZeroCore Power technology, AMD Unified Video Decoder (UVD), Projector Overlap Support, Bezel Compensation
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- OS Required
- Linux, Microsoft Windows 7 / 8.1 / 10
- Min RAM Size
- 256 MB
- Required Power Supply
- 350 W
- Additional Requirements
- Internet connection
- 75 Watt
- UL, VCCI, C-Tick, BSMI, FCC, RoHS, KCC, WEEE, DisplayPort 1.2
- Limited warranty - 3 years
