Everyday computing just got an upgrade
Incredible multi-core performance supercharged with AMD Radeon™ R3 Graphics - all on one processor
Efficient performance
The AMD Athlon processor is designed to deliver efficient and reliable performance for everyday computing tasks. Its architecture is optimized for smooth processing, ensuring a seamless user experience for browsing, office applications, and multimedia playback. -
Easy integration
With an installed quantity of 1, this processor is ready to fit into compatible systems, making it an ideal choice for builders looking for a straightforward upgrade or replacement solution. Its compatibility with a range of motherboards ensures a hassle-free integration into your current setup.
- AMD Athlon 5350 / 2.05 GHz processor - Box
- Product Type
- Processor
- Processor Type
- AMD Athlon 5350
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- Integrated Graphics
- Radeon R3 Series Graphics
- Compatible Processor Socket
- Socket AM1
- Processor Qty
- 1
- Clock Speed
- 2.05 GHz
- Manufacturing Process
- 28 nm
- Enhanced 3DNow! instructions set, MMX instructions set
- Product Type
- Processor
- Type / Form Factor
- AMD Athlon 5350
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- Cache Memory Details
- L2 - 2 MB
- Processor Qty
- 1
- Clock Speed
- 2.05 GHz
- Socket AM1
- 28 nm
- Thermal Design Power
- 25 W
- Architecture Features
Cache Memory
- Installed Size
- 2 MB
Integrated Graphics
- Base Frequency
- 600 MHz
- Package Type
- AMD Processor in a Box (PIB)
