This smart speaker features a sleek design and improved audio for vibrant sound anywhere in your home. With Echo Dot, you can stay on track with help from Alexa, control compatible smart home devices and start routines with your motion.
High-definition audio
Enjoy an improved audio experience for clearer vocals, deeper bass and vibrant sound in any room. -
Admire your favorite music and content
Play music, audiobooks, and podcasts from Amazon Music, Apple Music, Spotify and others or via Bluetooth throughout your home. -
Alexa Voice AI
Ask Alexa for weather updates and to set hands-free timers, get answers to your questions and even hear jokes. -
Keep your home comfortable
Control compatible smart home devices with your voice and routines triggered by built-in motion or indoor temperature sensors. Create routines to automatically turn on lights when you walk into a room, or start a fan if the inside temperature goes above your comfort zone. -
Designed to protect your privacy
Built with multiple layers of privacy controls, including a mic off button. -
Device pairing feature
Fill your home with music using compatible Echo devices in different rooms, create a home theater system with Fire TV.
- Amazon Echo Dot (5th Generation) - smart speaker
- Product Type
- Smart speaker
- Clock
- Speaker Type
- Active
- Display
- LED
- Bluetooth, Wi-Fi
- Intelligent Assistant
- Alexa built-in - direct
- Streaming Services
- Deezer, Spotify, Apple Music, Amazon Music, Audible
- Speaker Details
- Speaker - mono - active
- Cloud blue
- 10 cm x 10 cm x 8.9 cm
- 349 g
- 1-year warranty
- Product Type
- Smart speaker
- Clock
- Light
- LED light ring
- Hands-Free Function
- Microphone
- Sensors
- Motion sensor, temperature sensor
- Enclosure Colour
- Cloud blue
- Enclosure Material
- 55% post-consumer recycled plastic, 95% post-consumer recycled fabric
Speaker System
- Speaker Type
- Active
- Multiroom
- Amplifier
- Integrated
- Bluetooth, IEEE 802.11a/b/g/n/ac
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Internet Streaming Services
- Controls
- Volume, play/pause, snooze, mute microphone
- App-Controlled
- Display
- LED
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Integrated
- Communications Type
- Cloud
- Alexa built-in
- Voice Control
- Direct
Speaker System Details
- Speaker Details
- Driver Details
- Full-range driver - 1.73"
- Included Accessories
- AC power adaptor
- Power Source
- AC power adapter
- 10 cm
- 10 cm
- 8.9 cm
- 349 g
- Limited warranty - 1 year
