Amazon Echo Dot (4th Gen) Twilight Blue - EE Alexa Calling Offer
Quicklinx: G7X5WS00 Mfr#: B084J4T28D-ALEXACALLING
Complete any room with Alexa. The smart speaker has a sleek, compact design that fits perfectly into small spaces. It delivers crisp vocals and balanced bass for full sound you can enjoy anywhere in your home.
See the time, alarms and timers on the LED display. You can tap the top to snooze an alarm.
  • Alexa is happy to help
    Make your life easier at home. Set timers, ask questions, add items to lists, and create calendar events and reminders. Check the traffic and weather, or listen to the news. Access tens of thousands of Alexa skills, such as TV Guide or Fitbit. All using just your voice.
  • Voice control your home
    Manage compatible smart home devices using your voice. Switch on the lamp before getting out of bed, dim the lights from the sofa to watch a film, or turn the thermostat down as you head out.
  • Stay connected and in sync
    Instantly drop in on other rooms in your home or make an announcement to every room that has a compatible Echo device. Let everyone know dinner is ready, or remind the children that it's bedtime. You can also stay in touch with friends and family with hands-free calling.
  • Designed to protect your privacy
    Alexa and Echo devices are built with multiple layers of privacy protection. Echo smart speakers have a Microphone Off button that electronically disconnects the microphones. You also have control over your voice recordings and can view, hear or delete them at any time.
Amazon Echo Dot (4th Generation) - smart speaker
Smart speaker
Speaker Type
Active
Wi-Fi, Bluetooth
Intelligent Assistant
Alexa built-in - direct
Streaming Services
Spotify, Amazon Music, Apple Music, Audible
Speaker Details
Speaker - mono - active
Twilight blue
10 cm x 10 cm x 8.9 cm
328 g
1-year warranty
Smart speaker
Hands-Free Function
Microphone
Enclosure Colour
Twilight blue
Enclosure Material
50% recycled plastic, recycled aluminium, recycled textile
Speaker System
Speaker Type
Active
Multiroom
Amplifier
Integrated
IEEE 802.11a/b/g/n/ac, Bluetooth
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Internet Streaming Services
Controls
Volume, mute microphone
App-Controlled
Internet of Things (IoT)
Hub
Integrated
Alexa built-in
Voice Control
Direct
Speaker System Details
Speaker Details
Driver Details
Full-range driver - 1.6"
Connector Type
Audio line-out (mini-phone stereo 3.5 mm)
AC power adaptor
Power Source
AC power adapter
10 cm
10 cm
8.9 cm
328 g
Limited warranty - 1 year
