Amazon Echo Buds
Amazon Echo Buds
Quicklinx: GY4TWS00 Mfr#: B07FWGBDN6
Everything you love about Alexa, now in true wireless earbuds. Enjoy premium sound, limit background noise with Bose Active Noise Reduction. Advanced microphones give you hands-free access to Alexa - no tapping required.
  • Voice control your entertainment
    Alexa is always ready to help you play music, identify an artist, or listen to a podcast or Audible audiobook. Just ask to skip songs, switch artists, or turn it up while your hands keep air drumming.
  • Take Alexa with you
    Now you can leave your phone in your pocket. Just ask Alexa to set a reminder, check your calendar, make a call, or get directions. Or press and hold your earbud to access Siri or Google Assistant from a supported device.
  • Power up for work or play
    Long-lasting battery and the charging case let you go with the flow, no matter what your day holds.
  • Designed to protect your privacy
    Alexa and Echo devices are built with multiple layers of privacy protection. For example, with Echo Buds, you can mute the mics with the Alexa app. You also have control over your voice recordings. You can view, hear, or delete them at any time.
Amazon Echo Buds - true wireless earphones with mic
True wireless earphones - Bluetooth
Recommended Use
Portable electronics
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Active Noise Canceling
Noise Isolating
Microphone Operation Mode
Beamforming
Controls
Mute, voice assistant
Intelligent Assistant
Siri, Google Assistant, Alexa
1-year warranty
True wireless earphones - Bluetooth - wireless
Dimensions & Weight Details
Charging case: 7.7 cm x 5.7 cm x 2.9 cm / 70 g , Earbud: 2.2 cm x 2.3 cm x 2.4 cm / 7.6 g
Recommended Use
Protection
Sweat-resistant, water-resistant
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Bluetooth Profiles
Hands-Free Profile (HFP), Serial Port Profile (SPP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Sound Output Mode
Stereo
Noise Isolating
Active Noise Cancelling Technology
Microphone
Built-in
Beamforming
Remote Control
Controls
Tracking
Sensors
Accelerometer, proximity sensor, touch sensor
Connector Type
USB (5 pin Micro-USB Type B)
Internet of Things (IoT)
3 pairs of ear tips (small, medium, large), 3 pairs of wing tips (small, medium, large)
Cable Details
Micro-USB charge cable
IPX4
Headphone battery rechargeable
Run Time (Up To)
5 hour(s)
Run Time Details
Continuous playback: up to 5 hours , Continuous playback (with included charging case): up to 20 hours , Continuous talk (with included charging case): up to 16 hours , Continuous talk: up to 4 hours
Limited warranty - 1 year
