Amazon Echo (4th Gen) - Blue
Quicklinx: FZY6WS00 Mfr#: B085HWZY1K
Colours:
  • New look, new sound—Echo delivers clear highs, dynamic mids and deep bass for rich, detailed sound that automatically adapts to any room.Voice control your entertainment—stream songs from Amazon Music, Apple Music, Spotify, Deezer and more. Plus listen to radio stations, podcasts and Audible audiobooks.
  • Ready to help—ask Alexa to play music, answer questions, play the news, check the weather, set alarms, control compatible smart home devices and more.
  • Smart home made simple—with the built-in hub, easily set up compatible Zigbee devices to voice control lights, locks and sensors.
  • Fill your home with sound—with multi-room music, playing synchronised music across Echo devices in different rooms. You can also pair your Echo with Fire TV to feel scenes come to life with home cinema audio.
  • Connect with others—call almost anyone hands free. Instantly drop in on other rooms or announce to the entire household that dinner's ready.
  • Designed to protect your privacy—built with multiple layers of privacy protection and control, including a Microphone Off button that electronically disconnects the microphones.
Meet the all-new Echo
Talk about well-rounded. Echo combines premium sound, a built-in Zigbee smart home hub and a temperature sensor. Powerful speakers deliver clear highs, dynamic mids and deep bass for rich, detailed sound that adapts to any room. Just ask Alexa to play music, answer questions, make calls and tell you the news, sports scores, weather and more.
"Alexa, play music everywhere."
Use your voice to play a song, artist or genre through Amazon Music, Apple Music, Spotify, Deezer and more. With multi-room music you can fill your entire home with music, radio stations, podcasts and Audible using compatible Echo devices in different rooms. You can even pair with Fire TV to feel scenes come to life with home cinema audio.
Voice control your home
The built-in smart home hub lets you easily set up and manage dozens of smart devices that use Zigbee. Just turn on compatible lights, plugs, sensors and locks and say, "Alexa, discover my devices".
Alexa is happy to help
Make your life easier at home. Set timers, ask questions, add items to lists, and create calendar events and reminders. Check the traffic and weather, or listen to the news. Access tens of thousands of Alexa skills, such as TV Guide or Fitbit. All using just your voice.
Stay connected and in sync
Instantly drop in on other rooms in your home or make an announcement to every room that has a compatible Echo device. Let everyone know dinner is ready, or remind the children that it’s bedtime. You can also stay in touch with friends and family with hands-free calling.
Alexa and Echo devices are built with multiple layers of privacy protection. Echo smart speakers have a Microphone Off button that electronically disconnects the microphones. You also have control over your voice recordings and can view, hear or delete them at any time.
Every day is an earth day
You don't have to be an environmental scientist to make sustainable choices. Amazon considered sustainability in the design of this device. Here's how:
Materials
  • 50% of the plastics used are post-consumer recycled plastics.
  • 100% of the fabric used is post-consumer recycled fabric.
  • 100% of the aluminium used is recycled die-cast aluminium.
  • Device, cable and adaptor included.
Clean Energy
Amazon is building new wind and solar farms to produce clean energy equivalent to the electricity used by this device.
Device Packaging
99% of this device’s packaging is made of wood fibre-based materials from responsibly managed forests or recycled sources.
Low Power Mode
To reduce its energy consumption, this device will enter Low Power mode when it is idle. Low Power mode is not available for certain user configurations
Amazon Echo (4th Generation) - smart speaker
Smart speaker
Speaker Type
2-way - active
Wi-Fi, Bluetooth
Platform
Hue, Ring
Intelligent Assistant
Alexa built-in - direct
Streaming Services
Spotify, Amazon Music, Apple Music, SiriusXM internet radio, Pandora, Audible
Twilight blue
14.4 cm x 14.4 cm x 13.3 cm
970 g
1-year warranty
Smart speaker
Hands-Free Function
Microphone
Enclosure Colour
Twilight blue
Enclosure Material
50% recycled plastic, 100% recycled fabric, 100% recycled aluminium
Speaker System
Speaker Type
2-way - active
Multiroom
Amplifier
Integrated
IEEE 802.11a/b/g/n/ac, Bluetooth
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Internet Streaming Services
Controls
Volume, mute microphone, action
App-Controlled
Internet of Things (IoT)
Hub
Integrated
Platform
Hue, Ring
Communications Type
Cloud
Alexa built-in
Voice Control
Direct
Speaker System Details
Driver Details
Woofer driver - 3" - neodymium , 2 x tweeter driver - 0.8"
Connector Type
Audio line-in / audio line-out (mini-phone stereo 3.5 mm)
AC power adaptor
Power Source
AC power adapter
14.4 cm
14.4 cm
13.3 cm
970 g
Limited warranty - 1 year
