- Our most popular smart speaker: now available with an LED display that can show the time, outdoor temperature or timers.
- Perfect for your bedside table: ask Alexa to set an alarm, tap the top to snooze. The light sensor automatically adjusts the display’s brightness, day or night.
- Voice control your music: stream songs from Amazon Music, Apple Music, Spotify, Deezer, TuneIn and others. You can also listen to audiobooks from Audible.
- Enjoy stereo sound: pair with a second Echo Dot (3rd generation) for rich, stereo sound. Fill your home with music using compatible Echo devices in different rooms.
- Ready to help: ask Alexa to play music, answer questions, read the news, check the weather, set alarms, control compatible smart home devices and more.
- Alexa has skills: with tens of thousands of skills and counting, Alexa is always getting smarter and adding new ones, such as tracking fitness, playing games and more.
- Voice control your smart home: turn on lights, adjust thermostats and more, with compatible connected devices.
- Designed to protect your privacy: built with multiple layers of privacy protection and control, including a Microphone Off button that electronically disconnects the microphones.
- You can now use your Echo device to receive doorbell notifications and motion alerts.
Echo Dot—now with a clock
Our most popular Echo is now even better. This version of Echo Dot also has an LED display that can show the time, outdoor temperature or timers. Play music, get the news, call almost anyone and control compatible smart home devices—just ask Alexa.
Information at a glance
Ask Alexa for a timer and see the countdown. Ask for the weather and see the temperature. The LED display also has a light sensor that automatically adjusts brightness so you can see the time, day or night.
"Alexa, play top hits."
Use your voice to play a song, artist or genre through Amazon Music, Apple Music, Spotify, Deezer and TuneIn. With compatible Echo devices in different rooms, you can fill your entire home with music as well as listen to Audible or radio stations.
Alexa is happy to help
Make your life easier at home. Use your voice to set timers, add items to lists and create calendar events and reminders. You can also check the news, weather or traffic. Ask for sports scores, film screening times or information.
Manage compatible smart home devices using your voice. Switch on the lamp before getting out of bed, turn on the coffee machine on your way to the kitchen, or dim the lights from the sofa to watch a film.
Connect with your friends and family
Make hands-free calls to almost anyone including UK mobile and residential numbers (from UK only, emergency calling not supported), other Echo devices and the Alexa app. You can also link Alexa with your UK EE mobile phone account to ask Alexa to make and answer your mobile calls. Use Announcements to send voice messages to every room with an Echo device, or use Drop In as a two-way intercom between rooms.
Alexa has skills
With tens of thousands of skills and counting, Alexa is always getting smarter. Skills are like apps and help you do more, such as play relaxing sounds or test your music knowledge. Just say, "Alexa, what are your top skills?"
Alexa and Echo devices are built with multiple layers of privacy protection. For example, Echo Dot with clock has a Microphone Off button that electronically disconnects the microphones. You also have control over your voice recordings. You can view, hear or delete them at any time.
Stream songs from popular services. You can also listen to audiobooks. -
Rich sound
Enjoyr rich, stereo sound. Fill your home with music with other Echo devices in different rooms. -
Ready to help
Ask Echo to play music, answer questions, read the news, cheque the weather, set alarms, control compatible smart home devices, and more. -
Turn on lights, adjust thermostats, lock doors, and more with compatible connected devices. -
Built with multiple layers of privacy controls, including a microphone off button that electronically disconnects the mics.
- Amazon Echo Dot (3rd Generation) - smart speaker
- Product Type
- Smart speaker
- Clock
- Localisation
- United Kingdom
- Speaker Type
- Active
- Bluetooth, Wi-Fi
- Intelligent Assistant
- Alexa - direct
- Streaming Services
- Deezer, Spotify, TuneIn, Apple Music, Amazon Music, Audible
- Speaker Details
- Speaker - mono - active
- Sandstone
- 9.9 cm x 9.9 cm x 4.3 cm
- 300 g
- 1-year warranty
- Product Type
- Smart speaker
- Clock
- Microphone
- 4 microphones array
- Enclosure Colour
- Sandstone
- Localisation
- United Kingdom
Speaker System
- Speaker Type
- Active
- Multiroom
- Amplifier
- Integrated
- Bluetooth, IEEE 802.11a/b/g/n
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Internet Streaming Services
- Controls
- Volume, mute microphone, action
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Integrated
- Communications Type
- Cloud
- Alexa
- Voice Control
- Direct
Speaker System Details
- Speaker Details
- Connector Type
- Audio line-out (mini-phone stereo 3.5 mm)
- Included Accessories
- AC power adaptor
- Power Source
- AC power adapter
- 9.9 cm
- 9.9 cm
- 4.3 cm
- 300 g
- Limited warranty - 1 year
