Allied Telesis UTP-FIBRE SC MEDIA CONVERT
Quicklinx: 796TWS00 Mfr#: AT-MC102XL-30
£53.54 ex VAT
£64.24 inc VAT
The Allied Telesis' range of Fast Ethernet Media converters provides a complete series of conversion devices, allowing users to extend the size of UTP and multi-mode fiber networks with the use of single-mode fiber cabling. Supporting SC-connected single-mode fiber, these converters can be used to extend networks up to a distance of 2km.
All these media converters feature an internal MDI/MDIX switch, allowing the converter to be connected to PC, hub or switch with a simple UTP cable. The media converters also allow the installer to test the integrity of fiber connection, by forcing the converters to communicate over the fiber cable. This Link Test feature allows installers to check for cable faults without the need for expensive fiber optic test equipment.
Allied Telesis AT MC102XL - fibre media converter - 10Mb LAN, 100Mb LAN
Fibre media converter - RJ-45 / SC multi-mode
External
United Kingdom
Cabling Type
100Base-FX, 100Base-TX
Data Transfer Rate
100 Mbps
Optical Wave Length
1300 nm
10Mb LAN, 100Mb LAN
Max Transfer Distance
2 km
10.5 cm x 9.5 cm x 2.5 cm
0.3 kg
External
United Kingdom
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
1300 nm
2 km
Status Indicators
Power, link OK, test mode, receive
Full duplex capability, MDI/MDI-X switch, VLAN support
IEEE 802.1Q
1 x Ethernet 100Base-FX - SC multi-mode female - 2 , 1 x Ethernet 100Base-TX - RJ-45 female - 1
External power adapter
6 Watt
10.5 cm
9.5 cm
2.5 cm
0.3 kg
5 - 95%
Brand: Allied Telesis
