The Allied Telesis' range of Fast Ethernet Media converters provides a complete series of conversion devices, allowing users to extend the size of UTP and multi-mode fiber networks with the use of single-mode fiber cabling. Supporting SC-connected single-mode fiber, these converters can be used to extend networks up to a distance of 2km.
All these media converters feature an internal MDI/MDIX switch, allowing the converter to be connected to PC, hub or switch with a simple UTP cable. The media converters also allow the installer to test the integrity of fiber connection, by forcing the converters to communicate over the fiber cable. This Link Test feature allows installers to check for cable faults without the need for expensive fiber optic test equipment.
- Allied Telesis AT MC102XL - fibre media converter - 10Mb LAN, 100Mb LAN
- Fibre media converter - RJ-45 / SC multi-mode
- Form Factor
- External
- Localisation
- United Kingdom
- Cabling Type
- 100Base-FX, 100Base-TX
- Data Transfer Rate
- 100 Mbps
- Optical Wave Length
- 1300 nm
- Data Link Protocol
- Max Transfer Distance
- 2 km
- 10.5 cm x 9.5 cm x 2.5 cm
- 0.3 kg
- Form Factor
- External
- Localisation
- United Kingdom
- Connectivity Technology
- Wired
- Cabling Type
- 100 Mbps
- 1300 nm
- 2 km
- Status Indicators
- Power, link OK, test mode, receive
- Full duplex capability, MDI/MDI-X switch, VLAN support
- IEEE 802.1Q
- 1 x Ethernet 100Base-FX - SC multi-mode female - 2 , 1 x Ethernet 100Base-TX - RJ-45 female - 1
- Power Device
- External power adapter
- 6 Watt
- 10.5 cm
- 9.5 cm
- 2.5 cm
- 0.3 kg
- 0 °C
- 40 °C
- 5 - 95%
