Allied Telesis Allied Telesyn 1000SX Desktop Fibre PCI-X NIC
Quicklinx: 7W1PWS00 Mfr#: AT-2931SX/SC-001
Wired / Wireless: Wired
Protocol: Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
£130.85 ex VAT
£157.02 inc VAT
Gigabit connectivity through fiber to server and desktop.
Allied Telesis AT-2931SX/SC - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI hot-plug
PCI Specification Revision
PCI 2.2
Ports
1000Base-SX
1.3 cm x 17.8 cm x 5.1 cm
85 g
Cabling Type
Ethernet 1000Base-SX
GigE
Max Transfer Distance
500 m
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1ad
Novell NetWare 5.x, Novell NetWare 6.x, Microsoft Windows 2000 / XP, Linux 2.4.x
Microsoft Certification
Works with Windows Vista
Network adapter
Plug-in card
PCI hot-plug
PCI 2.2
Ports
1000Base-SX
Wired
Cabling Type
Gigabit Ethernet
Data Transfer Rate
1 Gbps
500 m
TCP/IP, UDP/IP
Status Indicators
Link/activity
Flow control, auto-negotiation, load balancing, VLAN support, full duplex mode
1 x 1000Base-SX - SC multi-mode - x 2
Compatible Slots
1 x PCI hot-plug
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
UL, VCCI, EN55022 Class B, FCC
1.3 cm
17.8 cm
5.1 cm
85 g
10 °C
55 °C
10 - 95%
Compatibility: PC
Brand: Allied Telesis
Price Range Ex VAT: 100 - 150
