Designed for Socket A 462
AMD Athlon XP 3400+ and all Socket A Sempron.
AK-786 is a low-noise, high performance value cooler. AK-450 thermal compound is pre-applied. New production technology has produced this high performance value cooler.
Features:
- Lo-noise high performance cooler.
- Hi-performance thermal compound is pre-applied.
- Akasa AK 786 - processor cooler
- Product Type
- Processor cooler
- Compatibility
- Socket A
- Fan Diameter
- 70 mm
- Fan Height
- 15 mm
- Fan Bearing
- Ball bearing
- Rotation Speed
- 3200 rpm
- Air Flow
- 20 cfm
- Noise Level
- 28.5 dBA
- Product Type
- Processor cooler
Heatsink & Fan
- Compatible With
- Socket A
- Processor Compatibility
- Athlon XP - up to 3400+ , Sempron
- Heatsink Dimensions
- 80 mm x 70 mm x 43 mm
- Fan Diameter
- 70 mm
- Fan Height
- 15 mm
- Fan Bearing
- Ball bearing
- Rotation Speed
- 3200 rpm
- Air Flow
- 20 cfm
- Noise Level
- 28.5 dBA
Customer reviews
Write a review for the Akasa XP3400+ Sempron Cooler here!
Tricky but quiet.
Reviewed by Anonymous Review Posted 24/08/2007
Quite difficult to clip down if you have the socket near the PSU. Performs extremely well.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
