Akasa Venom A10 Single Radiator Liquid CPU Cooler
Quicklinx: CK1VWS00 Mfr#: AK-LC4001HS01
Features:
  • All-in-one liquid cooler design for easy installation
  • High precision CNC Copper base for high efficiency heat transfer
  • New low noise 4-pole pump reduces vibration
  • Durable large diameter tubes provide smooth and quiet flow
  • Low noise Viper fan with S-FLOW blades
  • Integrated white LED indicator
Akasa Venom A10 AK-LC4001HS01 - liquid cooling system radiator with fan
Liquid cooling system radiator with fan
Package Content
Power cable, thermal paste, screws, backplane, spacers, back plate spacer, Clip for AMD, fan cable splitter, Intel clip, thermal compound, 120mm fan, spring nuts, insulating protective tape
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA1151 Socket, Socket FM3+
Heatsink Material
Copper
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
600-1900 rpm
Air Flow
83.63 cfm
Rated Voltage
12 V
White LEDs, S-FLOW blades, reinforced four layer tube, oxygen-free copper base, U-shaped micro fin flow path design, Viper fan
Package Content
Heatsink & Fan
Compatible With
Heatsink Material
Copper
Heatsink Dimensions
153 mm x 120 mm x 27 mm
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
600-1900 rpm
Air Flow
83.63 cfm
Air Pressure
2.98 mm
Rated Voltage
12 V
Mounting Kit
Included
