Akasa USB 3.0 SuperSpeed Memory Card Reader
Quicklinx: 8205WS00 Mfr#: AK-ICR-14
Conveniently positioned at the front of your PC, this SuperSpeed six slot USB 3.0 card reader accepts all popular cards in a single location. It includes a USB 3.0 port for extra connectivity and easy to install.
  • Interfaces: USB 3.0
  • Compatible Bays: 1 x front accessible - 3.5"
  • Connections: 1 x SuperSpeed USB 3.0 - internal 19 pins header
Akasa SuperSpeed Memory Card Reader - card reader - USB 3.0
Card reader - internal
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, xD-Picture Card, Memory Stick PRO Duo, CompactFlash Card, MultiMediaCardmobile, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, xD-Picture Card Type H, xD-Picture Card Type M, SDXC Memory Card
Host Interface
USB 3.0
Required Bay
3.5" internal
Status indicator
Host Interface
USB 3.0
Required Bay
3.5" internal
Status indicator
Memory Card
(max)
Additional Ports
1 x USB 3.0
Required Ports
1 x 9 pin USB Type A
Microsoft Windows 2000/XP/Vista/7
Plug and Play
