Conveniently positioned at the front of your PC, this SuperSpeed six slot USB 3.0 card reader accepts all popular cards in a single location. It includes a USB 3.0 port for extra connectivity and easy to install.
- Interfaces: USB 3.0
- Compatible Bays: 1 x front accessible - 3.5"
- Connections: 1 x SuperSpeed USB 3.0 - internal 19 pins header
- Akasa SuperSpeed Memory Card Reader - card reader - USB 3.0
- Product Type
- Card reader - internal
- Supported Memory Cards
- CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, xD-Picture Card, Memory Stick PRO Duo, CompactFlash Card, MultiMediaCardmobile, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, xD-Picture Card Type H, xD-Picture Card Type M, SDXC Memory Card
- Host Interface
- USB 3.0
- Required Bay
- 3.5" internal
- Status indicator
- Product Type
- Host Interface
- USB 3.0
- Required Bay
- 3.5" internal
- Status indicator
Memory Card
- Capacity
- (max)
- Additional Ports
- 1 x USB 3.0
- Required Ports
- 1 x 9 pin USB Type A
- OS Required
- Microsoft Windows 2000/XP/Vista/7
- Plug and Play
